Wooo Hoo! I think I got it. I put in a For loop and had it loop AFTER the Digital Write Low sequence. With 20 loops, the motor rotates 360 degrees 4 1/4 times. Which should be good enough...
Thank you all for putting up with me and sharing your knowledge and time.
Suggest you use a loop that runs every 2.5ms for each of the 2048 steps, about 5 seconds per revolution.
This way you give the motor enough time to move. i.e. do not run stepping at full speed.
Also, you can make your sketch non-blocking doing this.
Please post your sketch for new people that might have the same problem.
/* ___ ___ ___ _ _ ___ ___ ____ ___ ____
* / _ \ /___)/ _ \| | | |/ _ \ / _ \ / ___) _ \| \
*| |_| |___ | |_| | |_| | |_| | |_| ( (__| |_| | | | |
* \___/(___/ \___/ \__ |\___/ \___(_)____)___/|_|_|_|
* (____/
* This sketch is about how to use the MQTT protocol to control a step motor
* Tutorial URL http://osoyoo.com/2017/05/17/nodemcu-lesson-16-step-motor-mqtt/
* CopyRight www.osoyoo.com
* modified by inthenash 2024/08/19
* Special thanks to LarryD, davidefa, MicroBahner, DaveX from Arduino.CC Forum
* https://randomnerdtutorials.com/esp8266-pinout-reference-gpios/
* https://www.youtube.com/watch?v=9KFbgEBwMSc
* Equipment: NodeMCU; 28Byj-48 stepper motor 5v; ULN2003 driver
* Power: external 6.1 volts; NodeMCU will be ok at 6v (however do your own research to confirm)
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Stepper.h>
// Update these with values suitable for your network.
const char* ssid = "*******";//put your wifi ssid here
const char* password = "************";//put your wifi password here
//const char* mqtt_server = "iot.eclipse.org";
const int stepsPerRevolution = 500; // change this to fit the number of steps per revolution. This is NOT revolution of the motor spindle, but coil revolutions.
// initialize the stepper library on D1,D2,D5,D6 - note these are the pins on the NODEMCU.
//GPIO numbers are 5, 4, 14, 12
Stepper myStepper(stepsPerRevolution, D1, D5, D2, D6); // this specific order is very important to hit the correct coils in the correct order. I used these pins because they are all set low at boot.
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi() {
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Command from MQTT broker is : [");
Serial.print(topic);
int p =(char)payload[0]-'0';
// step one revolution in one direction:
if(p==1)
for (int x = 0; x < 20; x++) {
myStepper.step(stepsPerRevolution);
// myStepper.off() - kill all power to the stepper motor;
digitalWrite(5, LOW);
digitalWrite(4, LOW);
digitalWrite(14, LOW);
digitalWrite(12, LOW);
Serial.print(" clockwise" );
// step one revolution in the other direction:
else if(p==2)
for (int y = 0; y < 20; y++) {
myStepper.step(-stepsPerRevolution);
Serial.print(" counterclockwise" );
// Serial.println();
//end callback
void reconnect() {
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
//if you MQTT broker has clientID,username and password. Make sure to surround in ""
//please change following line to if (client.connect("clientId","userName","passWord"))
//if (client.connect(clientId.c_str()))
if (client.connect("clientID","userName","passWord"))
Serial.println("connected");
//once connected to MQTT broker, subscribe command if any
client.subscribe("blinds");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 6 seconds before retrying
delay(6000);
} //end reconnect()
setup_wifi();
client.setServer("192.168.1.70", 1883); //note if using home assistant, this is the homeassistant.local IP and the mqtt port assigned in your mqtt configureation.
client.setCallback(callback);
// set the speed at 80 rpm:
myStepper.setSpeed(80);
if (!client.connected()) {
reconnect();
client.loop();
