Hello guys, please after running the codes below, the timer works perfectly but only LED lights A and B on the ULN2003 power up instead of all the four LED lights. Hence the motor does not spin at all. Please I am new to this so kindly help me solve this issue. Thank you
Arduino codes:
//This code is to use with DS1302 RTC module, it permits you to setup the actual time and date
//And you can visualize them on the serial monitor
#include <virtuabotixRTC.h> //Library used
#include <AccelStepper.h>
//Wiring SCLK -> 6, I/O -> 7, CE -> 8
//Or CLK -> 6 , DAT -> 7, Reset -> 8
//int Relay = 7;
virtuabotixRTC myRTC(5, 4, 2); //If you change the wiring change the pins here also
// Motor pin definitions:
#define motorPin1 12 // IN1 on the ULN2003 driver
#define motorPin2 11 // IN2 on the ULN2003 driver
#define motorPin3 10 // IN3 on the ULN2003 driver
#define motorPin4 9 // IN4 on the ULN2003 driver
#define MotorInterfaceType 8
byte OnHour = 14;
byte OnMin = 18;
byte OffHour = 14;
byte OffMin = 19;
void StartMotor(){
AccelStepper stepper = AccelStepper(MotorInterfaceType, motorPin1, motorPin3, motorPin2, motorPin4);
stepper.setMaxSpeed(1000);
stepper.setAcceleration(100);
stepper.setSpeed(3500);
stepper.runSpeed();
pinMode(MotorInterfaceType, OUTPUT);
digitalWrite(MotorInterfaceType, HIGH);
// Set the current date, and time in the following format:
// seconds, minutes, hours, day of the week, day of the month, month, year
myRTC.setDS1302Time(50, 18, 14, 5, 9, 7, 2021); //Here you write your actual time/date as shown above
//but remember to "comment/remove" this function once you're done
//The setup is done only one time and the module will continue counting it automatically
//stepper.setSpeed(2500);
//stepper.runSpeed();
// This allows for the update of variables for time or accessing the individual elements.
myRTC.updateTime();
// Start printing elements as individuals
Serial.print("Current Date / Time: ");
Serial.print(myRTC.dayofmonth); //You can switch between day and month if you're using American system
Serial.print("/");
Serial.print(myRTC.month);
Serial.print("/");
Serial.print(myRTC.year);
Serial.print(" ");
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
if (myRTC.hours == OnHour && myRTC.minutes == OnMin) {
digitalWrite(8, HIGH);
StartMotor();
Serial.println("MOTOR ON");
else if (myRTC.hours == OffHour && myRTC.minutes == OffMin) {
digitalWrite(8, LOW);
Serial.println("MOTOR OFF");
// Delay so the program doesn't print non-stop
