28byj-48 to move on button press
Hey!
Ive just started a to build a 3d printed car that will use 28byj-48 and Ul2003n drivers. I will eventually use a app for controll.
The issue ive come to in tests is to just keep the motor turning while something is true. Im using the Accelstepper library to be able to move all motors at the same time.
So what im looking for help with is to find a some fuctions or code to make that happen.
Welcome to the forum
Please post your best effort at a sketch to do what you require
ive tried this so far
#include <AccelStepper.h>
const int stepsPerRevolution = 2048;  // change this to fit the number of steps per revolution
// ULN2003 Motor Driver Pins
#define IN1 16
#define IN2 5
#define IN3 4
#define IN4 0
// initialize the stepper library
AccelStepper stepper(AccelStepper::HALF4WIRE, IN1, IN3, IN2, IN4);
  // initialize the serial port
  // set the speed and acceleration
  stepper.setMaxSpeed(3000);
  stepper.setAcceleration(1000);
  // set target position
  stepper.moveTo(stepsPerRevolution);
  if (stepper.distanceToGo() == 10){
    stepper.moveTo(2*stepper.currentPosition());
  // move the stepper motor (one step at a time)
  stepper.run();
and also this
#define IN1 16
#define IN2 5
#define IN3 4
#define IN4 0
  stepper.setAcceleration(50);
stepper.setSpeed(2000);
stepper.runSpeed();
The main issue with the second part of code is that when its uploaded to the Esp8266 the motor starts to vibrate but now turning. But if i turn the shaft a bit by hand first it starts to spin as normal. There is a bit of resistance when i move it by hand. It is almost like the motor stalls...
How is the motor powered and at what voltage ?
from a lab power supply, set to 11v. Input is 5-12v. So have tried a few diffrent voltages but same issues...
show your setup
