28BYJ-48 with ULN2003 only humming
I just started with a very basic stepper motor control using an arduino nano, uln2003 board and a 28BYJ-48 5v stepper motor. Because using the Stepper and AccelStepper libraries did not work for me a went back to the basics.
A schema of the wiring ;
The code i used ;
#define IN1  8
#define IN2  9
#define IN3  10
#define IN4  11
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  int ddelay = 1000 ;
  while (true) {
    for (int step = 0 ; step < 9 ; step++) {
      //Serial.println(step) ;
      switch (step) {
        case 0:
          digitalWrite(IN1, LOW);
          digitalWrite(IN2, LOW);
          digitalWrite(IN3, LOW);
          digitalWrite(IN4, HIGH);
        case 1:
          digitalWrite(IN3, HIGH);
        case 2:
          digitalWrite(IN4, LOW);
        case 3:
          digitalWrite(IN2, HIGH);
        case 4:
        case 5:
          digitalWrite(IN1, HIGH);
        case 6:
        case 7:
        default:
      delay(ddelay) ;
      ddelay = ddelay - 10 ;
      if (ddelay < 10) {
        ddelay = 10 ;
What i have checked or done.
  • Reversed the order of the wires to the ULN2003
  • Changed batteries Ikea LADDA 2450 wit Panasonic Aerocell. The latter pair has been tested in a small robot driving 2 steppers.
  • Increased voltage to 9 v
  • Swapped stepper motor
  • Swapped ULN2003
When i run the code all leds on the uln2003 are on, the leds which i would expect to be on are more bright than the others. If i disconnect the stepper motor only the leds which are HIGH are one.
Any suggestions?
The ULN2003 is the SMD version uln2003A_64 (ti 18ycwfm)
'Motor only vibrates' almost always means the connections to the stepper are not in the right sequence.
See this page for examples and code: http://arduino-info.wikispaces.com/SmallSteppers
Yes, but the ULN2003 board and the stepper are off the shelve i would expect that the order is ok. So took a multimeter and checked the pinout of the ULN chip package and the pins on the stepper motor connector.
My expectation was;
Blue IN 1 Pink IN 2 Yellow IN 3 Orange IN 4 Red +5V
When i measured, it as (on the connector side)
Blue +5V Pink IN 1 Yellow IN 2 Orange IN 3 Red IN 5
After rewiring the connector in the order (top to bottom) red,blue, pink, yellow, orange it rotates!
On the board the wiring is.
+------+ | +5v | | IN1 | IN2 | | IN3 | IN4 | +-----+
This are the boards i used
It Rotates!
Good!
