28byj stepper motor
I need some help please. I'm new to this. I got a 28BYJ stepper motor and I'm wanting to control it with a L298N dual H bridge. Is this possible? Only thing I've found so far is connecting the common from the motor to +5v on the dual H and the other leads as u would a bipolar stepper. Do I need to just get an ULN2003? Any advice is greatly appreciated. Thanks!
You can control that motor using an L298 H-bridge, if you ignore the common lead (leave it unconnected) and pretend that it is a bipolar motor. You will need a 12 V power supply. You will probably have to swap pairs of leads around until it works properly.
It is a common myth that a five-wire stepping motor won't work when used as bipolar, but people who repeat that myth have most likely never tried it. I have tried a number of five-wire motors with several different H-bridges, and all worked well.
