28BYJ48 Stepper - gears, knobs whatnot supply?
Anyone know where I can find things that fit onto the output shaft of this stepper motor?
I'm not having much luck with figuring out proper wording for a search.
5mm shaft with two flat sides on it.
I think this says that it's 3mm for distance between the two flat spots.
Almost done with my project here, and don't have a way to attach to the motors!
Have a look at this company.
The gears you probably want are at the bottom.
I think I have the same motor. You don't measure between the flats, you measure the outer circumference of the shaft. Mine is a 5mm shaft. You probably want the metric plastic spur gears.
I'm in Australia, so shipping is usually about 10x the cost of the actual product.
Good Luck.
Rob.
Nothing I can use.
So, time to talk to the 3D printer guy at work. :slight_smile:
ah well...
Gotta love having a 3D printer. I've had mine for little over 4 years. And learned to use Solidworks just for gears. :sunglasses:
Well, drat.
On a slightly separate issue, my project doesn't look like battery operation is a viable option.
Two of these steppers on 8 step motion on an Arduino Nano --- runs at ~500mA.
500mA is a bit much for any kind of lifespan out of AA batteries.
sigh
Backup option of plug in power it is.
t'll run on batteries, just not for more than 4 hours or so.
