2A Dual Motor Controller + PWM Problem
i have this Motor Controller from DFRobot
http://www.dfrobot.com/index.php?route=product/product&path=51_105&product_id=66#.UVVjrqPQiE8
PWM Value from 0-127 didn’t work (LEDs didn’t showing)
PWM Value from 128-255 works fine, but running same fast.
How did it?
Here the code.
int E1 = 13;
int M1 = 12;
int E2 = 11;
int M2 = 10;
    pinMode(E1, OUTPUT);
    pinMode(M1, OUTPUT);
    pinMode(E2, OUTPUT);
    pinMode(M2, OUTPUT);
  int value;
  char val;
  while(1)
    val=Serial.read();
    if(val!=-1)
      switch(val)
        case '1': value=100;  //<------------- PWM didn't work, Motor not running!!!!!!
        case '2': value=255;
        case 's'://stop
        digitalWrite(M1, LOW);
        digitalWrite(E1, LOW); //<------------- Motor Speed
        digitalWrite(M2, LOW);
        digitalWrite(E2, LOW);
        case 'q'://Forward left
        digitalWrite(M1, HIGH);
        analogWrite(E1, value); //<------------- Motor Speed
        digitalWrite(E2, HIGH);
        case 'w'://Forward
        case 'e'://Forward right
        digitalWrite(M2, HIGH);
        case 'y'://Backward left
        case 'x'://Backward
        case 'c':// Backward right
http://www.christian-elektronik.de/
For PWM you need to analog write the Enable (E1 (13) , E2 (11)) pins, not digital write... But pin 13 isn't a PWM pin in the first place.
Check the sample code at the site you linked.
The PWM pins are marked with a printed "~" on the board. analogWrite on a non-PWM pins acts just as you've described.
