I did try reseting the board manually during uploading a couple of times to try and get it to reprog but no luck, the only way I was able to get it working again was to re-burn the boot loader manually.
The only reason I didn’t post this code before is because it’s mucho big, 600 lines big…
[EDIT]
well it seems I can’t post all my code because I exceeded the max allowed length of 9500 chars…
Anyway the majority of this code was all working before I added that for loop in there. After the loop is added it gets pissed off. Also as an experiment I isolated the code I though was problematic in an isolated sketch to see if this would brick it, and it didn’t! It only bricks the atmega328 when it’s in the original code.
Isolated code test:
#define defaultScale 1 //default scale to start at if none is coosen minor
#define defaultKey 2 //default key to start in if none is choosen D
//this 2D array contains all the scale data
byte scaleValues [50] [10] = {
{0,2,4,5,7,9,11,12,14,16},
{0,2,3,5,7,9,11,12,14,15},
{0,2,3,5,7,8,11,12,14,15},
{0,2,5,7,9,12,14,17,19,21},
{0,3,5,7,10,12,15,17,19,22},
{0,3,5,6,7,10,12,15,17,18},
{0,2,5,7,10,12,14,17,19,22},
{0,3,5,6,8,10,11,13,15,17},
{0,2,3,5,7,9,10,12,14,15},
{0,2,4,5,7,9,10,12,14,16},
{0,1,3,5,7,8,10,12,13,15},
{0,2,4,6,7,9,11,12,14,16},
{0,1,3,5,6,8,10,12,13,15},
{0,1,3,4,6,7,9,10,13,15},
{0,2,3,5,6,8,9,11,14,15},
{0,2,4,6,8,10,14,16,18,20},
{0,3,4,7,8,11,15,16,19,20},
{0,2,4,7,9,12,14,16,19,21},
{0,1,4,5,7,8,11,12,13,16},
{0,1,4,6,8,10,11,12,13,16},
{0,2,4,6,8,9,10,14,16,18},
{0,1,3,5,7,9,11,12,13,15},
{0,2,4,6,9,10,12,14,16,18},
{0,1,4,5,8,9,12,13,16,17},
{0,2,4,6,7,8,10,12,14,16},
{0,2,3,6,7,8,10,12,14,15},
{0,2,3,4,6,7,8,9,11,12},
{0,2,3,5,6,8,9,11,12,14},
{0,2,4,6,8,10,12,14,16,18},
{0,1,3,4,6,7,9,10,12,13},
{0,2,4,5,6,8,10,12,14,16},
{0,2,4,6,7,9,10,12,14,16},
{0,1,3,4,6,8,10,12,13,15},
{0,2,3,5,7,8,10,12,14,15},
{0,2,5,7,9,10,12,14,17,19},
{0,0,0,0,0,0,0,0,0,0},
byte noteValues [12] = {60,61,62,63,64,65,66,67,68,69,70,71};
byte notes[10];
void setup(){
Serial.println("BEGIN!");
//load default notes into system
for(int i = 0; i < 10;i++){
notes[i] = noteValues[defaultKey] + scaleValues[defaultScale] [i];
Serial.println(notes[i]);
Serial.println("Shortly after the fail");
void loop(){
Serial.println("looping...");
Here is the original code: warning this code is messy and long
because I can’t add all my code, here is the top portion of it that contains the offending code:
/* Laser Harp Controller
* Eric Goodchild
* 4/15/12
* Revision History: V1.6.2
* Added support for other scales
#include <avr/interrupt.h>
#include <stdlib.h>
#include <avr/io.h>
#include <MIDI.h>
#include <SoftwareSerial.h>
#define laserTrig 2 //Laser sensor trigger from TAOS sensor
#define galvoDrive 9 //Galvo amp output +-5VDC
#define laserBlanking 8 //laser blanking control
#define beamHold 500 //beam hold time in uS
#define beamBlank 600 //veam balnk time in uS
#define Period 1 //PWM period in microseconds
#define DATAOUT 11 // SDI pin 7 on AD5206
#define SPICLOCK 13 // CLK pin 8 on AD5206
#define SLAVESELECT 10 // CS pin 5 on AD5206
#define harpCenter 128 // ceneter posision of beams
#define trigEnable 4
#define statLED 19 // statis LED
#define OCSW 3 //Open close stoggle switch closed = HIGH open = LOW
#define upOct 5 //pedle pressed = HIGH
#define downOct 6 //pedle pressed = HIGH
#define pedal 7
#define defaultDetune -12
#define softTx 9
#define softRx 14
SoftwareSerial LCD(softRx, softTx); // RX, TX
//this array conatains the 16 byte scale names
char* scaleNames [50] = {
"Major",
"Minor",
"Harmonic Minor",
"Pentatonic Major",
"Pentatonic Minor",
"Pentatonic Blues",
"Pentatonic Neutr",
"Aeolian",
"Dorian",
"Mixolydian",
"Phrygian",
"Lydian",
"Locrain",
"Dim Half",
"Dim Whole",
"Whole",
"Augmented",
"Blues",
"Diatonic",
"Double Harmonic",
"Enigmatic",
"Lead Whole Tone",
"Neoploitan Major",
"Neoploitan Minor",
"Prometheus",
"6 Tone Sym",
"Lydian Minor",
"Lydian Dim",
"9 Tone Scale",
"Aux Dim",
"Aux Aug",
"Aux Dim Blues",
"Major Locrian",
"Overtone",
"Dim Whole Tone",
"Pure Minor",
"Dominant 7th",
"User Def 1",
"User Def 2",
"User Def 3",
"User Def 4",
"User Def 5",
"User Def 6",
"User Def 7",
"User Def 8",
"User Def 9",
"User Def 10",
"User Def 11",
"User Def 12",
"User Def 13"
//this array conatains the base note names
char* noteNames [12] = {"C","C#","D","D#","E","F","F#","G","G#","A","A#","B"};
//this array contains the base note values
int detune = -12;
unsigned int pwmPeriod;
unsigned int beamPosition = 128; //the location of the beam 0 - 100 range. start in center
unsigned long dutyCycle = 50;
unsigned long currentMillis = 0;
unsigned long timeStamp = 0;
boolean beamAdvance = false;
boolean strings[12];
boolean playing[12];
byte notes[10];
byte Dminor[10] = {
60,62,63,65,66,68,70,72,74,75};
int beamPos[10] ={
-102,-77,-51,-26,0,25,51,75,102,127};
volatile boolean trigged = false;
void setup(){
byte clr;
pinMode(statLED, OUTPUT);
pinMode(OCSW, INPUT);
pinMode(upOct, INPUT);
pinMode(downOct, INPUT);
pinMode(pedal, INPUT);
pinMode(trigEnable, OUTPUT);
pinMode(laserTrig,INPUT);
pinMode(galvoDrive, OUTPUT);
pinMode(laserBlanking, OUTPUT);
pinMode(DATAOUT, OUTPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); // desabilita dispositivo
digitalWrite(laserBlanking, LOW); //start with blanking enabled
digitalWrite(trigEnable,HIGH);
digitalWrite(statLED,HIGH); //turn off statis LED
attachInterrupt(0, beamTrig, LOW); //attach the beam trigger interrupt
MIDI.begin(1);
LCD.begin(9600);
//setup SPI
SPCR = (1<<SPE)|(1<<MSTR);
clr=SPSR;
clr=SPDR;
delay(10);
//move beam to ceneter start
spi_transfer(5);
spi_transfer(harpCenter);
//Clear the LCD
LCD.write(254);
LCD.write(1);
LCD.print("Laser Harp V1.6e");
LCD.print("Booting");
//display booting screen
for(int i =0;i<=3;i++){
LCD.print(".");
//clear LCD
LCD.write(254);
LCD.write(1);
LCD.print(" Harp Closed ");
while(digitalRead(pedal));
LCD.write(254);
LCD.write(1);
LCD.print(" Opening Harp ");
harpOpen(0.01, false);
LCD.write(254);
LCD.write(1);
LCD.print("Key:");
LCD.print(noteNames[defaultKey]);
LCD.write(254);
LCD.write(134);
LCD.print("Detune:");
LCD.print(detune);
LCD.write(254);
LCD.write(192);
LCD.print(scaleNames[defaultScale]); //print out default scale
