2D array into other 2D array
hy i'm making a program to drive 10 5*7 led matrixes
it will eventually be an alarmclock, but I want to make it possible to print text onto my displays.
because of this I defined all letters in 2D arrays so I know which leds have to go on and which not.
I used a switch case to send my letters into a transfer array to put it eventually into a larger (50+*7) array so I can use that to print the time. note that the length of the final array can differ and the content of it to, so I cannot hardcode it.
the problem is it never wants to compile because of the 2D array in the switch case. it most of the time gives me this problem code : cannot convert '' to int in assignment
i tried to fix it various ways, of which 3 are listed here
#define seven {\
    {1, 1, 1, 1, 1, 0}, \
    {0, 0, 0, 0, 1, 0}, \
    {0, 0, 0, 1, 0, 0}, \
    {0, 0, 1, 0, 0, 0}, \
    {0, 0, 1, 0, 0, 0}}
#define eight {\
    {0, 1, 1, 1, 0, 0}, \
    {1, 0, 0, 0, 1, 0}, \
    {0, 1, 1, 1, 0, 0}}
#define nine {\
    {0, 1, 1, 1, 1, 0}, \
    {0, 1, 1, 1, 0, 0}}
int matrix[7][6];
String spaces = "         ";
const int row[7] = {};
//cathodes
const int col[50] = {};
//anodes
const byte pixels[7][50];
void CharacterChoise(char character)
  switch (character)
          case'7':
      matrix = {\
    {0, 0, 1, 0, 0, 0}}
      case '8':
      matrix = eight
    case'9':
      for (int i = 0; i < 7; i++)
        for (int j = 0; j < 6; j++)
          matrix[i][j] = nine[i][j];
    default:
void PrintWords(String woorden)
  String prints = String(spaces + woorden + spaces);
  byte woordLeds[(strlen(prints) * 6][7];
                 for (int i = 0; i < (strlen(prints) * 6; i += 6)
  character[7][6] = CharacterChoise[prints[i / 6]];
      for (int k = 0; k < 7; k++)
        woordLeds[k][i + j] = character[k][j];
  for (int i = 0; i < (strlen(prints) * 6; i++)
  for (int j = 0; j < 50; j++)
        pixels[k][j] = woordLeds[k][i + j];
    for (int j = 0; j < 100; j++)
      PrintScreen();
void PrintScreen() {
  // iterate over the rows (anodes):
  for (int thisRow = 0; thisRow < 7; thisRow++) {
    digitalWrite(row[thisRow], LOW);
    for (int thisCol = 0; thisCol < 50; thisCol++) {
      int thisPixel = pixels[thisRow][thisCol];
      digitalWrite(col[thisCol], thisPixel);
  digitalWrite(row[thisRow], HIGH);
  delay(10);
i've already read dozens of topics to find the solution but saidly i couldn't find it.
does anyone had this problem before?
thanks for the help in advance.
greetz,
RayanR
Well thank you, that just fixed it. Won't it now take up more RAM?
solution
int nine[7][6] = {\
    {0, 1, 1, 1, 0, 0}};
I just changed the defines to int blabla[7][6] = {{……},{.... .....}}.
