2D array, read row in reverse without using a nested for loop?
Still learning, but sometimes I come across a simple problem that becomes intractable, leading me to doubt my sanity.
I have the following arrays:
//Track Note data
boolean trackArray[4][16] = {
    1,0,0,1,0,1,0,0,0,0,0,0,1,0,0,0    }
    0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0    }
    0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0    }
    0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0    }
//Track Assignment data
byte trackLength[] = { // Current Length of all tracks
  16,16,16,16,16,16,16,16};
byte trackPosition[] = { // Current index of all tracks
  1,1,1,1,6,4,1,3};
byte trackNote[] = { // Current MIDI Note for all tracks
  36,38,40,58,60,42,44,46};
byte trackChan[] = { // Current MIDI Channel for all tracks
  10,10,10,10,10,10,10,10};
byte trackVelMax[] = { // Current maximum velocity for all tracks
  127,100,100,100,100,100,100,100};
What I do is iterate though the 4 tracks of the 2D array and select the current note on/off status per step.
I can do this no problem using a for loop to cycle through the tracks, something like…
for (int i = 0; i < 8; i++ ) { //Loop through the 8 Tracks
      int notetoplay = trackArray[i][trackPosition[i]]; 	//Selects the note to play based on position in the track
      if (notetoplay == 1) {   					//indicates Note-on
        MIDI.sendNoteOn(trackNote[i],trackVelocity[i],trackChan[i]);
        MIDI.sendNoteOff(trackNote[i],0,trackChan[i]);
	trackPosition[i]++;					//Update Track Position
        if (trackPosition[i] >15) {trackPosition[i] = 0;} //Rotate the array
Which works fine.
However, what if I want to read the notes in reverse based on the trackPosition. For example, instead of reading the first row in this order…
I instead read it in reverse…
0,0,0,1,0,0,0,0,0,0,1,0,1,0,0,1
I don’t want to alter the array - just read it. I’ve looked for an elegant way to do this but I’m stumped.
An ideas?
Many kind thanks in advance.
:slight_smile:
I'm not qoute sure about the structure but you could either count the index backwards
for(int i = 7; i >= 0; i--){}
or calculate the index when it is used
int notetoplay = trackArray[i][trackPosition[7-i]]
I'm also not sure, but I think you have create a new variable for going up or down.
Old code
    trackPosition[i] = 0;             //Rotate the array
New code. This code can change the direction, so when the position is 3, you can go to 4 or 2. That is what the boolean variable is used for. If you want to start always at 15 and go downwards, the code needs to be different.
boolean trackForward = true;
  if (trackForward) {                  // test if forward
    if (trackPosition[i] >= 15)
      trackPosition[i]++;
  else {                                            // reverse
    if (trackPosition[i] == 0)
      trackPosition[i] = 15;             //Rotate the array
      trackPosition[i]--;            //Update Track Position
nilton61:
D’oh! So simple. Thanks.
:slight_smile:
