I am going to build a simple circuit for current measurement. I am facing a problem in measuring a current range from 2mA- 30mA for my project. FYI, my system operates at 3.5- 5V. Any recommendation for the selection of components(both amplifier & shunt resistor)?
as my current sense amplifier. But for the current sensing resistance, I am not too sure what is the value to be used in my application ( Measuring 2mA -30mA )..
Can anyone please share their knowledge? Thanks.
Following link is the available range of current sensing resistance:
Decide what you want the output voltage to be at full scale.
Divide that by the gain to give the required voltage drop across the resistor (there are 3 versions of the device with different gains).
Calculate the resistor value that gives the required voltage drop at 30mA.
