Hi
I have data that is in bytes
I can convert the bytes to integer
I can join 2 bytes to get a word and convert it to unsigned interger
BUT please help as to how I get the signed integer, I have seen it as 2s complement ???
My simple simple testing code is as below:
THANKS
byte testbyte=254;//(FE in HEX)
int signedINTword=0;
Serial.begin(115200);delay(2000);
signedINTword = word(testbyte, testbyte); // (FEFE in HEX)
Serial.println(valueH);
the result is 65278 which is technically correct (for unsigned integer)
how do I get the result in signed Integer
also called 2s complement ???
It will then be -258
Thanks
first consider what happens if you subtract 1 from a 2 byte signed variable having a value of zero, 0x0000. it underflows, becoming 0xffff. the most significant bit of a "signed" variable indicates its sign and 0xffff is the 2s complement value for -1. subtracting 1 again results in 0xfffe, -2 and so forth
consider subtracting 5 from a 2 byte signed variable with a value of 2. the variable starts with a value of 0x0002 and becomes 0xfffd which represent -3 in 2s complement.
similarly, if you add 6 to a 2 byte variable containing 0xfffd, it naturally overflows, and becomes 0x0003 which is now positive
Edit your first post using the in the tool bar just below your post
select the code part and press the <code/> icon in the tool bar to mark it as code. (also make sure you indented the code in the IDE before copying, that’s done by pressing ctrlT on a PC or cmdT on a Mac)
If your 2 byte thingy is in a variable already, just print it. You’ll see it in decimal (DEC is the default - not needed) or add that you want it in hexadecimal (HEX) or binary (BIN)
uint16_t var = 0xff18;
Serial.print(var); // in decimal
Serial.print(var, HEX); // in hexadecimal
Or Is your question about how to enter the string ?
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
The point being that it's undefined behaviour to /return/ from such a function, not to /write/ such a function.
in the second link there is this
There are programs that are valid and must not give an error.
int f() { }
int main() { }
This never calls f() so there is no problem. -Werror=return-type would fail to compile this valid program.
int g(bool b) { if (b) return 1; }
int main() { g(true); }
This program calls g(true) which is OK, it never calls g(false). -Werror=return-type would fail to compile this valid program.
The C++ standard says these programs must be accepted without errors. What GCC does is allow you to compile broken code, but it warns, and since GCC 13 it tries to prevent completely unpredictable undefined behaviour if you accidentally do fall off the end of a function without returning.
