2S LIPO Monitor
Hello FEllow Arduinites,
I've been trying for the past several days to come up with a LIPO cell voltage monitor, but failing to do so. I've read a lot of posts and borrowed some code, I'm close but not quite there yet. For example using my multi-meter I measure the voltage at the divider and I get 4.06v ,but when the arduino tells me the voltage on that cell it is 4.71. I know it's erroneous since the maximum voltage any single cell can have is 4.2v only. I'm only monitoring one cell until I figure out what's wrong, or somebody tells me where's my error.
BTW: I'm powering the Arduino with the same 2S Lipo battery.
Here's my code with the schem.
Schem for a 2S LIPO (7.4v/8.4v max):
LIPO (MAIN +) ------- 7.4v -------------------------------(Arduino pwr socket +)
                                                      ----(Arduino pwr socket -)
LIPO (Cell 2+) ----- 4.2v max ----(Arduino Pin A1)    |
                  10K ohms  10K ohms                  |
LIPO (Cell 1+) -----vvvv--|--vvvv---------------------|
                          |--4.2v---(Arduino Pin A0)  |
LIPO (GND-) ------------------------------------------|
Code:        */
#include <SparkSoftLCD.h>      // library to manipulate the SparkFun LCD backpack v2.5
#define CELL_1_PIN 14   // Analog Pin A0
#define CELL_2_PIN 15   // Analog Pin A1
#define LED_PIN 13      // Digital Pin 13
#define LCD_PIN 2       // Digital pin 2 to LCD
SparkSoftLCD LCD = SparkSoftLCD(LCD_PIN);
void setup(){
  pinMode(CELL_1_PIN, INPUT);
  pinMode(CELL_2_PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
  pinMode(LCD_PIN, OUTPUT);
  LCD.begin(9600);
  LCD.clear();
//  delay(1500);
void loop(){
  cellVolts();
  digitalWrite(LED_PIN,HIGH);
  cellVolts();
  digitalWrite(LED_PIN,LOW);
void cellVolts(){
  int cell1Volt, cell2Volt;
  LCD.cursorTo(1,1);
  LCD.print("Cell 1 voltage: ");
  LCD.cursorTo(2,1);
  cell1Volt = (analogRead(CELL_1_PIN)*5);
  LCD.print(cell1Volt / 1024, DEC);
  LCD.print(".");
  LCD.print(cell1Volt % 1024, DEC);
Any help, as always greatly appreciate it.
since you are working with decimals, wouldn't it be more appropriate for cell1volt and cell2volt to be floats?
The value returned by analogRead is a function of the operating voltage, which may not be 5.000, as your equation assumes.
You'll need to assure that your operating voltage is 5.000 or adjust the cell1Volt calculation.
