Two_Steppers.ino Arduining.com 30 MAY 2015
Driving two steppers concurrently with the Arduino Nano.
stepperX follows potentiometer on analog input 0.
stepperY follows potentiometer on analog input 1.
A timeout is used to turn off coils and save energy in battery
operated applications.
Hardware:
Arduino NANO.
Drivers: ULN2003A
Stepper Motors: 28BYJ48, 5VDC, step angle 5.625 °
Gear reduction 64:1
No-load starting frequency:> = 500PPS (4 rpm)
Coil resistance 60 Ohms.
#include <Stepper.h>
#include <Servo.h>
int val; // variable to read the value from the analog pin
#define STEPSREV 4096 // 64(fullsteps) * 64 (reduction ratio)
#define SPEED 4 // motor speed (RPM)
#define COIL_1X 8
#define COIL_2X 9
#define COIL_3X 10
#define COIL_4X 11
#define COIL_1Y 7
#define COIL_2Y 5
#define COIL_3Y 6
#define COIL_4Y 4
#define POT_X 0
#define POT_Y 1
#define TIMEOUT 1000 //Turns off after 1 sec of inactivity.
#define NOISE 8 //inmunity in steps because analog noisy readings.
// create the instances of the stepper class.
Stepper stepperX(STEPSREV, COIL_1X, COIL_2X, COIL_3X, COIL_4X);
Stepper stepperY(STEPSREV, COIL_1Y, COIL_2Y, COIL_3Y, COIL_4Y);
int potValX,potValY; // potentiometers analog readings
int Xpos,Ypos; // Actual steppers positions(0-4096)->(0-360°)
int newXpos, newYpos; // New steppers positions
unsigned long stampX, stampY; // last move time stamped.
Servo myservo; // create servo object to control a servo
int potpin = A2; // analog pin used to connect the potentiometer
//============== functions ====================================================
//Read the potentiometers and map the reading to mach 360 degrees.
void readPots(){
potValX = analogRead(POT_X); // read POT_X value (0-1023).
potValY = analogRead(POT_Y); // read POT_Y value (0-1023).
newXpos= map(potValX,0,1023,0,2047); // Map pot X range to one stepper turn.
newYpos= map(potValY,0,1023,0,2047); // Map pot Y range to the stepper turn.
// Aproach stepperX to the newX position.
void aproachX(int newX){
int Xdir = Xpos<newX ? 1 : -1;
stepperX.step(Xdir); // move one step in the Xdir direction.
Xpos += Xdir; // update Xpos.
stampX = millis(); // stamp actual time.
// Aproach stepperY to the newY position.
void aproachY(int newY){
int Ydir = Ypos<newY ? 1 : -1;
stepperY.step(Ydir); // move one step in the Ydir direction.
Ypos += Ydir; // update Ypos.
stampY = millis(); // stamp actual time.
//Check for inactivity and turn off the steppers coils to save battery.
void CheckTimeout(){
if((millis() - stampX) > TIMEOUT){ //Turn Off StepperX coils.
digitalWrite(COIL_1X, LOW);
digitalWrite(COIL_2X, LOW);
digitalWrite(COIL_3X, LOW);
digitalWrite(COIL_4X, LOW);
if((millis() - stampY) > TIMEOUT){ //Turn Off StepperY coils.
digitalWrite(COIL_1Y, LOW);
digitalWrite(COIL_2Y, LOW);
digitalWrite(COIL_3Y, LOW);
digitalWrite(COIL_4Y, LOW);
//=================== setup ===================================================
void setup(){
stepperX.setSpeed(SPEED); // set the X motor speed.
stepperY.setSpeed(SPEED); // set the Y motor speed.
readPots();
Xpos = newXpos;
Ypos = newYpos;
myservo.attach(29); // attaches the servo on pin 9 to the servo object
//================= main loop =================================================
void loop(){
readPots();
//if diference is greater than NOISE move steppers.
if(abs(newXpos - Xpos)> NOISE) aproachX(newXpos);
if(abs(newYpos - Ypos)> NOISE) aproachY(newYpos);
CheckTimeout(); //check for inactivity.
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
//delay(15); // waits for the servo to get there
with help from the internet and some playing around I have 2 steppers and one servo so far working my proplem is that when I had only 2 steppers my nema 17 56oz/in would scream along but when I added the servo into the sketch and all now goessss soooo slowwwww and I wanted to add more servos but will it come to a girding halt and be painfully slowwww I have one small stepper that comes with a arduino starter kit and driver and one nema 17 using a L298N driver all running from a PC power supply 5v at 25 amps running on a arduino mega also now my servo seams to chatter when sitting with everything at rest but when I up load the servo with knob sketch it doesn't do it
this is the sketch I started with from this site keep it simple please I am just learn and could us a bit of guidance sorry just one more add on how do I get more steppers added to this Thank you for any help
