2wd car problem of either wiring or coding
Hello, Im making an obstacle avoidance robot car and im aving a problem with the motors. Only one of them works. I was wondering if i need two use both of the enable pins (one for each motor). By the way, I'm using L298n driver. Thanks in advance.
If the ENA ENB pins are not enabled (connected to 5v or attached to PWM signals), the motor drivers will not work.
so i need to change the code to make it have 2 enable pins and 4 pins to control the motors ?
#include <Servo.h>          //Servo motor library. This is standard library
#include <NewPing.h>        //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 7;
const int LeftMotorBackward = 6;
const int RightMotorForward = 4;
const int RightMotorBackward = 5;
//sensor pins
#define trig_pin A0 //analog input 1
#define echo_pin A1 //analog input 2
#define maximum_distance 250
boolean goesForward = false;
int distance = 150;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  servo_motor.attach(10); //our servo pin
  servo_motor.write(115);
  delay(2000 );
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void loop(){
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
  while(1)
    moveForward();
    if (distance <= 20){
      moveStop();
int lookLeft(){
  servo_motor.write(170);
  int distance = readPing();
  delay(100);
  return distance;
  delay(100);
int readPing(){
  delay(70);
  int cm = sonar.ping_cm();
  if (cm==0){
    cm=250;
  return cm;
void moveStop(){
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
  if(!goesForward){
    Serial.println("==moveForward==");
    goesForward=true;
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
  goesForward=false;
  Serial.println("==moveBackward==");
  digitalWrite(LeftMotorBackward, HIGH);
  digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
  Serial.println("==turnRight==");
void turnLeft(){
  Serial.println("==turnLeft==");
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
What is the servo use for ?
