Hey, i m trying to make a simple robot car project: An automatic car that stops when an obstacle is near 10 cm and reverse the direction , i wrote the code and it didn't work as i wanted: the car stops when an obstacle is near and reverse the direction when it's gone !! , also the car rotate on its place ! Please help me thank you
////////CAPTEUR ULTRASON PORT
int trig = 2;
int echo = 3;
long lecture_echo;
long cm;
//////////////// BRIDGE L289
int IN4 = 13;
int IN3 = 12;
int IN2=9;
int IN1=8;
int enA=6;
int enB =5;
//Pour inverser la direction du moteur
int aux;
int y,x;
void setup(){
//Capteur ultrason
pinMode(trig, OUTPUT);
digitalWrite(trig, LOW);
pinMode(echo, INPUT);
//Bridge
pinMode(IN4, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN1,OUTPUT);
x=1;
y=0;
void loop(){
//Vitesse
analogWrite(enA,255);
analogWrite(enB,255);
// Signal capteurs envoie et reception
digitalWrite(trig, HIGH);
delayMicroseconds(10);
lecture_echo = pulseIn(echo,HIGH);
cm = lecture_echo /58;
Serial.print("Distance en cm :");
Serial.println(cm);
//test si la distance est inférieur a 10cm ( je voudrai inverser le sens)
if (cm<10){
 //inverse du sens
aux=y;
y=x;
x=aux;
//stop du moteur pendant 5s
digitalWrite(IN1, 0); // rotation sens 2
digitalWrite(IN2, 0);
 digitalWrite(IN3, 0); // rotation sens 2
 digitalWrite(IN4, 0);
//Roulement dans le sens inverse
digitalWrite(IN1, x); // rotation sens 2
digitalWrite(IN2, y);
 digitalWrite(IN3, y); // rotation sens 2
 digitalWrite(IN4, x);
/*************************FIN DU PROGRAMMES**************************/
