3.2 ITDB02 UTFT Shield: Rrror: conversion from 'int' to 'String' is ambiguous
Hello,
The code below works proberly with print out “Peter” but neither with Val nor A as variable.
The serial print works instead…
Thanks for any help!
Peter
Hardware: Arduino 2560 with 3.2 ITDB02 UTFT Shield
/*Example: Übernahme Analogwert
#include <UTFT.h>
UTFT myGLCD(ITDB32S,38,39,40,41);
extern uint8_t BigFont;
int Sensor=A0;
int Led=13;
int Val;
int A;
pinMode(Led, OUTPUT);
myGLCD.InitLCD();
myGLCD.clrScr();
Val=analogRead(0);
Serial.print("Val= “);
Serial.print(Val);
Serial.print(” Val+10= ");
A=(Val+10);
Serial.println(A);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 0);
myGLCD.setFont(BigFont);
//myGLCD.print(“Test”, CENTER, 100);
myGLCD.print(Val, CENTER, 100);
//myGLCD.print(A, CENTER, 100);
digitalWrite(Led, HIGH);
delay (Val);
digitalWrite(Led, LOW);
delay (Val);
Error report:
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: “Arduino Mega 2560 or Mega ADK”
Test.ino: In function ‘void loop()’:
Test:34: error: conversion from ‘int’ to ‘String’ is ambiguous
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:61: note: candidates are: String::String(const __FlashStringHelper*)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:59: note: String::String(const char*)
Might I refer you to the instructions? UTFT print options include - myGLCD.print(st,x,y); - myGLCD.printNumI(num,x,y); - myGLCD.printNumF(num,dec,x,y);
Regards,
Graham
Thanks a lot - it works now. Regards Peter
