Got a real odd one I can't work out - if I try out the demo UTFT code from Henning Karlsen everything works great. Now I"m trying some simple code to display something on the screen. It works but after a few seconds I get these weird vertical lines quickly flashing across the screen. I'm using the below code - the strange thing is if I remove this line then it works fine!
I'm thinking its got something to do with screen refreshes but I can't figure out what.
myGLCD.print("testing 1 2 3", 0, 40);
// http://henningkarlsen.com/electronics/library.php?id=34
#include <UTFT.h>
int x=0;
int y=0;
int z=0;
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next line for Arduino Mega
UTFT myGLCD(ITDB32S,38,39,40,41); // Remember to change the model parameter to suit your display module!
// SETUP
randomSeed(analogRead(0));
// Setup the LCD
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
myGLCD.clrScr();
myGLCD.printNumI(x, 0, 10);
myGLCD.printNumI(y, 0, 20);
myGLCD.printNumI(z, 0, 30);
x = x + 1;
y = y + 2;
z = z + 3;
