3.3v, 8MHz, SMD, which bootloader?
Hi guys, hoping for some help here.
I'm designing an RGB LED expansion board to be controlled via a serial connection. My question however, isn't so much related to what the board does, but how to program the atmega328 I intend to put on board.
I've prototyped successfully with an atmega328p-pu on an arduino uno. However, this is running at 5v and I intend to run my board at 3.3v (and 8MHz). All of the IC's etc that I'm using are 3.3v compatible so there's no problem there, my question is which bootloader and SMD part to pick for the microcontroller?
I see that there are several parts available including the ATMEGA328P-AU, however, which is the closest match to the Atmega328p-pu? Further to that, how do I select the correct bootloader for it? Is there a pre-done one available? In the past, my 3.3v boards have all used DIP parts so I was able to just use the Arduino Pro 3.3v 8Mhz bootloader, but I don't believe this will work with an SMD part?
Many thanks, Iestyn.
Writing manually:)
HOW TO PROGRAM THE ATMEGA328(p) MANUALLY THROUGH SPI
Programming the ATmega328(p) manually can easily be achieved using a standard SPI connection. By connecting the ATmega to a host MCU through SPI, programming the target can be very easy.
  1. ChipSelect - Enables programming mode on the target ATmega328(p)
  2. Issue corresponding commands from host to the target.
  3. Release ChipSelect ___________________________________________________________________________________
CONNECTIONS
HOST - TARGET SS/CS RESET MOSI MOSI MISO MISO SCK SCK V+ V+ GND GND
No external crystal connection is needed. Programming speed is determined by SPI SCK.
ATMEGA328(p) ISP COMMANDS
0xAC EXECUTABLE COMMAND PREFIX 0x20 READ LOW BYTE FROM FLASH 0x28 READ HIGH BYTE FROM FLASH 0x30 READ DEVICE ID INFORMATION 0x40 WRITE LOW BYTE TO FLASH BUFFER 0x48 WRITE HIGH BYTE TO FLASH BUFFER 0x4C TRANSFER BYTES FROM BUFFER TO FLASH AT ADDRESS LOADED INTO 0x40 AND 0x48 0xC0 WRITE BYTE TO EEPROM 0xA0 READ BYTE FROM EEPROM
OPCODE USAGE
STEP 1: Issuing the "Programming Enable" command to the target:
This is the only command the target will acknowledge initially when RESET goes low. You can enter Programming Mode by sending AC 53 00 00 to the target.
STEP 2: Reading the Device ID from the target after initialization:
The next step is to see if init occured correctly, so we have to read the Device ID from the target. Device ID can be read by issuing 30 00 00 to the target, and then read one byte back from the target checking for data first then issuing clock in that order on the bit level.
The Device ID byte should read back as 1E signifying Atmel as the manufacturer. If the Device ID byte reads as 0x1E, the device is set to be reprogrammed. If the Device ID byte reads as 0xFF, the device did not initialize properly.
If the Device ID byte reads as 0x00, then the Lock Bits are set and the device has to be erased first before you can properly read the Device ID.
Send three bytes, then read one byte for a total of four bytes in the sequence.
** Note that each command in Programming Mode is ALWAYS 4 bytes long ** ** You can also read flash size using 30 00 01 + read one byte ** ** You can also read device family using 30 00 02 + read one byte **
STEP 3: Issuing the Chip Erase Command to Erase the entire contents of Flash and EEPROM:
Before programming can occur, the Flash and EEPROM must be erased at the same time. This resets all bytes in the physical address space to 0xFF so they can be reprogrammed. Erasing Flash and EEPROM can be accomplished by issuing AC 80 00 00 to the target. ALL bytes in Flash and EEPROM become 0xFF.
** ATmega328(p) is only capable of setting individual bits to 0's from 1's during programming ** ** The unit can not program bits from 0's to 1's, so the bytes default to 0xFF after format **
STEP 4: Checking to see if the device was formatted properly:
Checking Flash to see if it was formatted properly can be done by issuing the Read Byte From Flash command. Each address location holds 2 bytes, a High byte and a Low byte.
aa=SEGMENT or MSB highbyte of address bb=OFFSET or LSB low byte of address
Example: If the Segment=00 and the Offset=01 then the ADDRESS= 0x0001
To read a low byte from an address in Flash, issue: 20 aa bb then read one byte, or issue: 20 SEGMENT OFFSET then read one byte.
To read a high byte from an address in Flash, issue: 28 aa bb then read one byte or issue: 28 SEGMENT OFFSET then read one byte.
If the bytes read are 0xFF, then the device has been formated properly. The Flash address range is 0x0000 - 0x03FFF or 0-16383 for a total of 16384 memory locations. ** Each address in Flash contains 2 bytes, a Low byte and a High byte **
STEP 5: Writing a byte to Flash after proper Format:
Writing bytes to flash occurs by sending a byte to a high or low location per address in flash.
Writing a low byte to a Flash address is accomplished by issuing 40 SEGMENT OFFSET uint8_t for a total of four bytes sent to the target from the host.
Writing a high byte to a Flash address is accomplished by issuing 48 SEGMENT OFFSET uint8_t for a total of four bytes sent to the target from the host.
Physically writing the low and high bytes to the flash from the buffer is done by issuing the "Write Program Memory Page" command which must be done per address location after having written the low and high bytes to a single address.
Locking the bytes into Flash memory can be done by issuing 4C SEGMENT OFFSET 00 for a total of four bytes sent to the target MCU.
Simply release the RESET line of the target MCU to end programming mode.
Example 40 00 00 FE 48 00 00 EF 4C 00 00 00 writes EFFE to address 0x0000 in Flash. Commands are issued one after another without releasing RESET, (which must remain low).
INTERPRETTING INTEL HEX FORMAT
Intel HEX format traditionally looks something like this: :107800000C94343C0C94513C0C94513C0C94513CE1
Understanding the bytes can be done by breaking each line of HEX code into groups like this:
:10 7800 00 0C94343C0C94513C0C94513C0C94513C E1
Each line in this bootloader example begins with a : representing the start of a new line.
The next two chars 0x10 from the example shows how many data bytes are in the line of text.
The next four bytes 0x7800 show the starting address where the code will be written to Flash with 0x78 as MSB or SEGMENT and 0x00 as LSB or OFFSET for the address.
The next two bytes 0x00 show that the next 16 bytes in the line are plain uint8 data. This will be written low byte first then high byte in that order until end of file.
Following the data type is a group of 16 bytes beginning with 0x0C ending with 0x3C 0x0C will be written as the low byte using ISP command 0x40 at address 0x7800 0x94 will be written as the high byte using ISP command 0x48 at address 0x7800
Then these bytes are locked into place inside the Flash using ISP command 4C 78 00 00 reflecting the address of the bytes that were issued to the buffer.
0x3C will be written as the high byte using ISP command 0x48 at address 0x7807 This is because the ATmega328(p) holds two bytes per address in Flash unlike the hex file shows.
The last two chars 0xE1 are the checksum digits for the entire line which can be discarded.
The last two lines in the hex file can be ignored as they will not be written to Flash in any shape, way or form. The last two lines of code look something like this: :040000030000780081 :00000001FF
They are not used for AVR, but used for storing instruction and stack pointer addresses in Intel x86 CPU's. The last line marks the end of file which can be ignored completely.
** Write the low byte, then write the high byte and then lock the bytes into place before writing any bytes to any other address ** ** The only address we are interested in is the very first address listed in the hex file, 7800 in this case for bootloader ** ** No other address should ever be used as the other addresses do not line up to how the data needs to be written to MCU Flash! **
BOOTLOADERS
ATmega328(p) has four bootloader locations inside it.
They are:
BLS1 - 0x7E00 - 0x7FFF size 0x0200 or 512 bytes
BLS2 - 0x7C00 - 0x7FFF size 0x0400 or 1024 bytes
BLS3 - 0x7800 - 0x7FFF size 0x0800 or 2048 bytes
BLS4 - 0x6FFF - 0x7FFF size 0x1000 or 4096 bytes
Per the example above, this bootloader begins at 0x7800 so we know we'll have to use Bootloader Section 3, BLS3. This will be the start address where the bootloader code will reside.
However, all Application Code should be written starting at address 0x0000 inside the MCU Flash without entering bootloader space unless the bootloader option is disabled.
Disabling the bootloader can be accomplished by setting [BOOTRST] to 0 which will set the Reset Vector address to 0x0000 during Power-Up.
This way, the bootloader is disabled and your Application Code will still work.
Disabling the bootloader will give your Application Code more space as it can then fill up the bootloader sections since execution starts at 0x0000.
Thanks for that, that's an excellent insight.
In the past, I had used a programming board that I built myself with an Arduino Uno as a host microcontroller to program bootloaders and sketches onto chips via SPI, as you described here.
As is suggested above, I can avoid using the bootloader entirely, but I believe I still need to do some configuration for the Arduino software (possibly to do with boards.h which I've seen mentioned a few times?) in order for the code to compile correctly for the way I want the chip to be set up.
Another option, which I've no idea how I can set up, is to use the internal oscillator if possible, set at 8MHz?
So to be clear: I'm asking: a) Which SMD chip is closest to the P-PU and thus easiest to transfer code over to? b) How do I get the compiler to compile code correctly for the chip setup I want: i) A particular SMD chip as specified in question a. ii) To run at 8MHz (possibly without an external oscillator if possible). iii) To run at 3.3V
Thanks in advance
Well, your programming code for the sketch enables modules in the hex file. The bootloader enables reprogramming acces via usb.
If you disable the bootloader BOOTRST 0, maybe uncheck the setting, You can throw your progra ming code in using the ISP mode through ISP if you're using another MCU to program the new MCU.
I used a uc3a3 Xplained evaluation board from Atmel, and had it rerouting data from USB CDC to the new ATMEGA328, but I implemented SPI with avr32 code gpio functions.
Feel free to read what I posted below, it describes all of the isp commands, and how to read data from the hex files and place them into the flash.
I also have a quick semo video showing the atmega328p blinking an led as a test after I wrote the sketch and bootloader in one shot. I was shocked it worked. I had to create a vb.net application to parce e hex files to get the binary data, but you can also do it by hand.
Here is my test video, but i would defitely place the new MCU in isp mode http://youtu.be/KezzU8PZMIc
The atmega328’s ship out with the clock set at 1 mhz from what I read. The divide by 8 fuse can be disabled to get back up to 16 mhz internally on powerup
I understand that I can program the chip directly via SPI, bypassing the bootloader, but will all due respect, that wasn’t what I was asking. I think we may be misunderstanding each-other.
Correct me if I’m wrong but my understanding is as follows; When you select a board in the IDE and compile, creating a hex file, it is compiled for the board selected with regard to selecting the correct implementation of functions such as hardware serial, SPI etc.
My chip (and hardware setup), (as far as I’m aware) doesn’t have a pre-existing board profile (at least not packaged with the arduino IDE). How do I create one, compatible with my hardware requirements:
→ 8MHz Clock (Internal oscillator preferred, or external is workable if this isn’t possible)
→ 3.3V
In addition to this, what is the most appropriate surface mount implementation of the Atmega328P-PU?
Regards
Use the bootloading loader here, it is much easier than reinventing the wheel.
You can choose 8MHz if you wish 3.3V bootloader if you need to.
The -pu and -au in the part number indicate the package; pu is PDIP throughhole, au is TQFP surface mount.
Not sure on bootloader - this is a question that I've been wondering too. I'd like to be able to use optiboot to maximize available flash space, but I don't know where/how to get an 8mhz version of it.
@DrAzzy, when I ran up Nick Gammon's bootloader, it offered the Lilly pad loader for a 328 at 8MHz. I'm not sure if that is with or without crystal, you would have to ask Nick. (I too would be interested)
ChilliTronix: @DrAzzy, when I ran up Nick Gammon's bootloader, it offered the Lilly pad loader for a 328 at 8MHz. I'm not sure if that is with or without crystal, you would have to ask Nick. (I too would be interested)
Yeah, but the lilypad bootloader is 2048 bytes instead of 512 like optiboot :-P
The Lillypad optiboot loader isn’t the same size as the Lillypad bootloader. (That said, I don’t know how big it is, Nick Gammon’s boot loader is here.)
Just use the stock 328 optiboot, and halve the upload speed in boards.txt so that you use 57600 instead 115200.
@Iexpress: You have already made the same (or similar) post about 5 times, the first being:
This is cross posting. Please stop or be banned. If you want to convey the same information post a link to your first post, don’t just copy and paste it again and again.
Iexpress: The atmega328's ship out with the clock set at 1 mhz from what I read. The divide by 8 fuse can be disabled to get back up to 16 mhz internally on powerup
So if you divide 16 by 8 you get 1, is that it?
