Hi guys
I am working on burning 3.3V internal 8M clk bootloader to ATMEGA 328P. And I got some problems.
Here is what I did: ( I did all these with a UNO R3)
- I started with 5V/8M internal clk bootloader, followed this link:
https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
I can burn the bootloader in, I can upload sketches.
Then I tried to lower the VCC from 5V to 3.3V. @4V, it still worked, @3.4V, it still worked, but @3.3V, the internal oscillator stopped working.
I thought it might be the BOD failure, so I change the efuse to 0xFF, same problem.
I gave it an external 16Mhz clk at 3.3V Vcc, everything just went back to normal.
- Then I tried a 3.3v/8Mhz internal clk Opti-bootloader. (same connection as above)
I can burn the bootloader, but can not upload any sketches. The error is like : "avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60" and repeated 10 times.
Change the efuse thing, still not work.
So my question is:
Can I make this work at 3.3V with 8Mhz internal clk? If so, which bootloader should I use?
