Help everyone- I have an Arduino Uno that I had setup today being powered by a pc. I was getting a strange reading on a sensor so I measured the 3.3v pin it was connected to and it read the same as the 5v output pins. In this case 5.11v. This was also true on the aref pin.
Before doing any testing disconnect everything and measure one more time. If it stays at 5 volts I would guess you fried the 3.3 volt regulator which has its input shorted to its output. The reason for this is it is supplied by the 5V regulator which is the output you are getting. Without physically having the device look if it got hot and the solder shorted some pads. The easiest way to validate this is to remove it and the 3.3 volts will go to about zero with a light load maybe a few K ohms. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Where was the volt meter's black probe connected? What was the voltage on the 5V pin? The VIN pin? Connect a 220Ω resistor from 3V3 pin to GND and test again. Post a link to the UNO seller's web page.
