3.3V SMT Buzzer
Does anyone know of a good SMT buzzer that is decently loud around 4KHz with a voltage of 3.3V? I purchased one off digi-key(102-1264-1-ND) and it is very quiet. I really like the foot print it just don't get the job done. I"m using it with a Lipo battery, an Arduino Pro 3.3V, and a simple NPN to turn it on and off.
If really loud is what you are after you are going to need to drive the piezo yourself with a driver incorporating an inductor in its output. Piezo elements are high impedance and require reasonable drive voltages to sound loudly. Virtually all wristwatches drive their piezo elements via a high inductance choke as the driver load.
not looking for really loud. Just looking to be able to hear it in a normal room say with the TV on. much like a wrist watch alarm. I have the buzzer right now on the collector side of the NPN transistor and the other leadoff the buzzer going to 3.3V and that is it. Any examples of a decent buzzer circuit for a 3.3v circuit? I don't have much experience with piezo or buzzers in general but i'm always willing to learn something new.
Specifications
Standard Package 1
Category Audio Products
Family Buzzers
Series CSS
Driver Circuitry Transducer, Externally Driven
Technology Magnetic
Input Type zero-peak Signal
Voltage - Rated 3Vo-p
Voltage Range 2 ~ 4V
Frequency 4kHz
Operating Mode Continuous
Sound Pressure Level 75dB @ 3V, 10cm
Current - Supply 110mA
Washable No
Mounting Type Surface Mount
Termination Solder Pads
Size / Dimension Square - 5.00mm L x 5.00mm W x 3.20mm H
Packaging Cut Tape (CT)
Capacitance @ Frequency -
Operating Temperature -30°C ~ 70°C
