3.5" Display issues
Hi all,
I got this display, but i am having limited success with it.
It's not dead, but i can't get any decent sketch to work properly.
The following code works, and looks great - but it is a bit low-level, and has limited functionality.
//Technical support:goodtft@163.com
// Breakout/Arduino UNO pin usage:
// LCD Data Bit :   7   6   5   4   3   2   1   0
// Uno dig. pin :   7   6   5   4   3   2   9   8
// Uno port/pin : PD7 PD6 PD5 PD4 PD3 PD2 PB1 PB0
// Mega dig. pin:  29  28  27  26  25  24  23  22
//              : PH4  PH3 PE3 PG5 PE5 PE4 PH6 PH5
#define LCD_RD   A0
#define LCD_WR   A1
#define LCD_RS   A2
#define LCD_CS   A3
#define LCD_REST A4
#define WR_MASK B00000010
#define RS_MASK B00000100
void Lcd_Writ_Bus(unsigned char d)
  PORTH &= ~(0x78);
  PORTH |= ((d&0xC0) >> 3) | ((d&0x3) << 5);
  PORTE &= ~(0x38);
  PORTE |= ((d & 0xC) << 2) | ((d & 0x20) >> 2);
  PORTG &= ~(0x20);
  PORTG |= (d & 0x10) << 1;
  PORTF &= ~WR_MASK;
  PORTF |=  WR_MASK;
void Lcd_Write_Com(unsigned char VH)
  PORTF &= ~RS_MASK;//RS=0
  Lcd_Writ_Bus(VH);
void Lcd_Write_Data(unsigned char VH)
  PORTF |= RS_MASK;//LCD_RS=1;
  Lcd_Writ_Bus(VH);
void Lcd_Write_Com_Data(unsigned char com,unsigned char dat)
  Lcd_Write_Com(com);
  Lcd_Write_Data(dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
        Lcd_Write_Com(0x2a);
	Lcd_Write_Data(x1>>8);
	Lcd_Write_Data(x1);
	Lcd_Write_Data(x2>>8);
	Lcd_Write_Data(x2);
        Lcd_Write_Com(0x2b);
	Lcd_Write_Data(y1>>8);
	Lcd_Write_Data(y1);
	Lcd_Write_Data(y2>>8);
	Lcd_Write_Data(y2);
	Lcd_Write_Com(0x2c);
void Lcd_Init(void)
  digitalWrite(LCD_REST,HIGH);
  delay(5);
  digitalWrite(LCD_REST,LOW);
  delay(15);
  delay(15);
  digitalWrite(LCD_CS,HIGH);
  digitalWrite(LCD_WR,HIGH);
  digitalWrite(LCD_CS,LOW);  //CS
  Lcd_Write_Com(0x11);
  delay(20);
  Lcd_Write_Com(0xD0);
  Lcd_Write_Data(0x07);
  Lcd_Write_Data(0x42);
  Lcd_Write_Data(0x18);
  Lcd_Write_Com(0xD1);
  Lcd_Write_Data(0x00);
  Lcd_Write_Data(0x07);//07
  Lcd_Write_Data(0x10);
  Lcd_Write_Com(0xD2);
  Lcd_Write_Data(0x01);
  Lcd_Write_Data(0x02);
  Lcd_Write_Com(0xC0);
  Lcd_Write_Data(0x3B);
  Lcd_Write_Data(0x11);
  Lcd_Write_Com(0xC5);
  Lcd_Write_Data(0x03);
  Lcd_Write_Com(0x36);
  Lcd_Write_Data(0x0A);
  Lcd_Write_Com(0x3A);
  Lcd_Write_Data(0x55);
  Lcd_Write_Com(0x2A);
  Lcd_Write_Data(0x3F);
  Lcd_Write_Com(0x2B);
  Lcd_Write_Data(0xE0);
  delay(120);
  Lcd_Write_Com(0x29);
  Lcd_Write_Com(0x002c);
void H_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  Lcd_Write_Com(0x02c); //write_memory_start
  digitalWrite(LCD_RS,HIGH);
  l=l+x;
  Address_set(x,y,l,y);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void V_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  l=l+y;
  Address_set(x,y,x,l);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  H_line(x  , y  , w, c);
  H_line(x  , y+h, w, c);
  V_line(x  , y  , h, c);
  V_line(x+w, y  , h, c);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  unsigned int i;
  for(i=0;i<h;i++)
    H_line(x  , y+i, w, c);
int RGB(int r,int g,int b)
{return r << 16 | g << 8 | b;
void LCD_Clear(unsigned int j)
  unsigned int i,m;
 Address_set(0,0,320,480);
  //Lcd_Write_Com(0x02c); //write_memory_start
  //digitalWrite(LCD_RS,HIGH);
  for(i=0;i<320;i++)
    for(m=0;m<480;m++)
      Lcd_Write_Data(j>>8);
      Lcd_Write_Data(j);
  for(int p=0;p<10;p++)
    pinMode(p,OUTPUT);
  DDRH |= 0x78;
  DDRE |= 0x38;
  DDRG |= 0x20;
  pinMode(A0,OUTPUT);
  pinMode(A1,OUTPUT);
  pinMode(A2,OUTPUT);
  pinMode(A3,OUTPUT);
  pinMode(A4,OUTPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, HIGH);
  digitalWrite(A4, HIGH);
  Lcd_Init();
 //LCD_Clear(0xf800);
   LCD_Clear(0xf800);
   LCD_Clear(0x07E0);
   LCD_Clear(0x001F);
  for(int i=0;i<1000;i++)
    Rect(random(300),random(300),random(300),random(300),random(65535)); // rectangle at x, y, with, hight, color
//  LCD_Clear(0xf800);
I got this code from here - after reading about it on the Banggood customer reviews.
I would like to get sketches using the Adafruit_GFX.h and Adafruit_TFTLCD.h libraries to work, but all i get with these is white-screen, i've tried graphicstest_kbv, but this give white screen as well.
Can anyone shed any light on what might be the problem here - there can't be much wrong?
Frustratingly, this sketch works, but looks awful, loads of flickering, graphics look poor. It uses an identifier of 0x9341, which surprises me. The packet the display came in claims that this is a ILI9486 driver. I cut most of the functions out as they don't really add any information.
// IMPORTANT: Adafruit_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Adafruit_TFTLCD.h FOR SETUP.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values:
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
void setup(void) {
  Serial.println(F("TFT LCD test"));
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
  Serial.println(F("Using Adafruit 2.8\" TFT Arduino Shield Pinout"));
#else
  Serial.println(F("Using Adafruit 2.8\" TFT Breakout Board Pinout"));
#endif
  Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
  tft.reset();
  uint16_t identifier = tft.readID();
identifier=0x9341;
  if(identifier == 0x9325) {
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if(identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if(identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
  } else if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  } else if(identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    return;
  tft.begin(identifier);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(CYAN));
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(RED, BLUE));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(GREEN));
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(YELLOW, MAGENTA));
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, WHITE));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
    delay(2000);
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(BLACK);
  tft.fillScreen(RED);
  tft.fillScreen(GREEN);
  tft.fillScreen(BLUE);
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
You appear to have a "Blue 3.5 inch Mcufriend" shield for Uno.
The ILI9481 versions overheat. Place your wrist on the bottom of panel after 10 minutes.
It should work out of the box with MCUFRIEND_kbv. Any version.
If it shows inverted colours, call tft.invertDisplay(true);
But most importantly, please tell me about any problems with graphictest_kbv example sketch.
Update via Library Manager if required. Copy-paste any diagnostic output.
David.
Thanks David - i'll check this evening.
I cleaned out all of the display libraries - and just loaded Adafruit and MCUFRIEND_kbv - and thank you David - it, as you said - just works. The colours don't look right, it looks like the hex-codes are wrong, for example when i set the text to RED, it might come out blue, not a big deal i supposed
When i try to run the SHOW_bmp_kbv sketch i get the following, and i would like to but a bmp on it.
Show BMP files on TFT with ID:0x9486
cannot start SD
I also don't notice it getting hot - i'm running on a Mega.
Run the graphictest_kbv sketch
Or even the diagnose_TFT_controller sketch.
Report back with actual colours. e.g. BLUE is Yellow, GREEN is displayed as Magenta and BLACK is displayed as White.
Or perhaps RED is displayed as Blue. BLUE is Red. GREEN is Green.
The showBMP_kbv_Uno sketch should run out of the box on a Uno.
The showBMP_not_Uno sketch gives special instructions on what to do for a Mega2560.
Your "Blue 3.5 inch Mcufriend" is common now. It is easy to fix the colours when I get an accurate report.
David.
will do David - i need to know these anyway - i'll report back when in the next couple of days
David: Colours are indeed inverted, they look fine once corrected. I'll put a post together later with more details on the graphictest_kbv sketch.
All colours look fine when running graphictest_kbv, i added the tft.invertDisplay(true); to the setup() method and everything looks great.
I'll can post some photos if you like? Anything specific you want to see?
I also notice that if these 3 lines are not commented out of the sketch
extern const uint8_t penguin[];
tft.setAddrWindow(wid - 40 - 40, 20 + 0, wid - 1 - 40, 20 + 39);
tft.pushColors(penguin, 1600, 1);
I get the following error during linking
AppData\Local\Temp\cczRf5ff.ltrans0.ltrans.o: In function main':** **cczRf5ff.ltrans0.o:(.text.startup+0x1e58): undefined reference to penguin'
cczRf5ff.ltrans0.o:(.text.startup+0x1e5a): undefined reference to `penguin'
collect2.exe: error: ld returned 1 exit status
It's not clear what they are for, or how to debug - C++ is not my language (I've started to read up on it, but C# is what i do professionally)
Thanks for your feedback.
You have confirmed that the Blue 3.5inch has inverted Colours
A recent message says that recent Red 3.5 inch 0x9486 displays have inverted Colours.
I will change the default behaviour in the Beta. This will not appear in the Library Manager until I make the next Release.
I would expect all library examples to "work". There should not be a penguin error.
The graphictest_kbv is too big for Leonardo. It should just squeeze into a Duemilanove.
I suggest that you make the single edit in MCUFRIEND_kbv.cpp:
    case 0x9486:
        _lcd_capable = AUTO_READINC | MIPI_DCS_REV1 | MV_AXIS; //Red 3.5", Blue 3.5"
//        _lcd_capable = AUTO_READINC | MIPI_DCS_REV1 | MV_AXIS | REV_SCREEN; //old Red 3.5"
You will not need to use invertDisplay() in example sketches.
If you have a problem, I suggest that you re-install with the Library Manager. Then make the "edit".
David.
hi, David. I tried this code and having a problem with turn on (start) SD card. this is the message that appears
"Show RAW files on TFT with ID:0x9486
cannot start SD"
Which Arduino are you using ?
The shield will only work on Uno
