I was wonder how to wire up an old 3.5 floppy drive motor. I'm I right in thinking that this motor is a small stepper motor? I have already taken the motor out and it only has four wires. I thought stepper motors had six??
I have no clue. noobie here. I just wanted to play around with one.
I also want to control my 3,5" floppy (bipolar) stepper motor. I already tried it but it doesn't turn, it only schockes from left to right.
I also have a unipolar stepper motor but I tried this:
I don't know how to connect te wires. When I connect the yellow, black, brown and orange to the digital ports and the red one to the ground, it turns. But when I disconnect the red wire it still turns, without a connection to the ground. It doesn't have much torgh too.
The floppy stepper motor has 4 wires and the unipolar stepper motor has 5 wires. I think the bipolar stepper motor doens't work because you also have to change current per coil.
The Arduino can't directly drive motors, so you will first need a driver , to amplify the signals from the Arduino to a level useful for the motor.
All the exciting details about a good bipolar driver are here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1138310274
You can drive a floppy step motor directly from the arduino. BUT you need to keep the floppy controller board. The control has a 5V logic interface that controls the steps, the direction and the home position sensor. I had to read all 3 of these before I understood it.
