3.5" TFT Display for Mega - Touch not working
I am trying to test my tft display, this is the model:
My board is Mega2560.
And the example code is shown below:
#include "UTFT.h"
#include <UTouch.h>
#include <UTFT_Buttons.h>
#include <SPI.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t Dingbats1_XL[];
// Set up UTFT...
// Set the pins to the correct ones for your development board
// Standard Arduino 2009/Uno/Leonardo shield   : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Standard chipKit Uno32/uC32                 : <display model>,34,35,36,37
// Standard chipKit Max32                      : <display model>,82,83,84,85
// AquaLEDSource All in One Super Screw Shield : <display model>,82,83,84,85
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ILI9486,38,39,40,41);
// Set up UTouch...
// Standard Arduino 2009/Uno/Leonardo shield   : 15,10,14,9,8
// Standard Arduino Mega/Due shield            : 6,5,4,3,2
// CTE TFT LCD/SD Shield for Arduino Due       : 6,5,4,3,2
// Standard chipKit Uno32/uC32                 : 20,21,22,23,24
// Standard chipKit Max32                      : 62,63,64,65,66
// AquaLEDSource All in One Super Screw Shield : 62,63,64,65,66
UTouch  myTouch(52, 48, 51,50, 49);
// Finally we set up UTFT_Buttons :)
UTFT_Buttons  myButtons(&myGLCD, &myTouch);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myButtons.setTextFont(BigFont);
  myButtons.setSymbolFont(Dingbats1_XL);
  int but1, but2, but3, but4, butX, butY, pressed_button;
  boolean default_colors = true;
  but1 = myButtons.addButton( 10,  20, 300,  30, "Button 1");
  but2 = myButtons.addButton( 10,  60, 300,  30, "Button 2");
  but3 = myButtons.addButton( 10, 100, 300,  30, "Button 3");
  but4 = myButtons.addButton( 10, 140, 300,  30, "Button 4", BUTTON_DISABLED);
  butX = myButtons.addButton(279, 199,  40,  40, "a", BUTTON_SYMBOL);
  butY = myButtons.addButton(  0, 199, 100,  40, "I", BUTTON_SYMBOL | BUTTON_SYMBOL_REP_3X);
  myButtons.drawButtons();
  myGLCD.print("You pressed:", 110, 205);
  myGLCD.setColor(VGA_BLACK);
  myGLCD.setBackColor(VGA_WHITE);
  myGLCD.print("None    ", 110, 220);
  while(1)
    if (myTouch.dataAvailable() == true)
      pressed_button = myButtons.checkButtons();
      if (pressed_button==butX)
        if (myButtons.buttonEnabled(but4))
          myButtons.disableButton(but4, true);
          myButtons.enableButton(but4, true);
      else if (pressed_button==butY)
        if (default_colors)
          myButtons.setButtonColors(VGA_YELLOW, VGA_RED, VGA_YELLOW, VGA_BLUE, VGA_GRAY);
          myButtons.relabelButton(butY, "_");
          default_colors=false;
          myButtons.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_BLUE);
          myButtons.relabelButton(butY, "I");
          default_colors=true;
      if (pressed_button==but1)
        myGLCD.print("Button 1", 110, 220);
      if (pressed_button==but2)
        myGLCD.print("Button 2", 110, 220);
      if (pressed_button==but3)
        myGLCD.print("Button 3", 110, 220);
      if (pressed_button==but4)
        myGLCD.print("Button 4", 110, 220);
      if (pressed_button==-1)
I can see that buttons on display but the problem is the touch, isn't working.
Someone can help me with some tips please?
Thanks in advance.
Post a link to the actual display that you bought. e.g. Ebay sale page.
I bought it here in Brasil, but probably the seller may bought it from ebay or aliexpress.
This is HERE
Thanks
Are you sure your display has a touch screen? The webpage you linked is for a non-touch screen display.
From your link:
Não é touch
The photo shows a TFT without a Touch Panel. And the description confirms it.
David.
Both of you are right,
My display isn't working because it has not touch function, I was scammed :confused:
Thanks friends
No, you were not scammed. You just did not read the description carefully.
There are several Ebay sellers that provide inaccurate descriptions. Most are due to ignorance. Some deliberately try to mislead you.
Always compare the item that you received with the photos and descriptions on the Sale site. If the seller is wrong you can get your money back.
Hey-ho. There are plenty of projects that will work just fine with your display.
David.
