Hi there,
I am using 3.5" TFT LCD Shield with Arduino Uno (tried on Mega, but the result is the same)
mcufrient_kbv diagnose_TFT_support returns the following:
Diagnose whether this controller is supported
There are FAQs in extras/mcufriend_how_to.txttft.readID() finds: ID = 0x0
MCUFRIEND_kbv version: 2.9.9
This ID is not supported
look up ID in extras/mcufriend_how_to.txt
you may need to edit MCUFRIEND_kbv.cpp
to enable support for this ID
e.g. #define SUPPORT_8347DNew controllers appear on Ebay often
If your ID is not supported
run LCD_ID_readreg.ino from examples/
Copy-Paste the output from the Serial Terminal
to a message in Displays topic on Arduino Forum
or to Issues on GitHubNote that OPEN-SMART boards have diff pinout
Edit the pin defines in LCD_ID_readreg to match
Edit mcufiend_shield.h for USE_SPECIAL
Edit mcufiend_special.h for USE_OPENSMART_SHIELD_PINOUT
Based on the manufacturer it's using ILI9486 driver.
LCD_ID_readnew returns the following
Read Special Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)diagnose any controller
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 00 00 00 00 00 Status Register
reg(0x000A) 00 00 Get Power Mode
reg(0x000C) 00 00 Get Pixel Format
reg(0x0030) 00 00 00 00 00 PTLAR
reg(0x0033) 00 00 00 00 00 00 00 VSCRLDEF
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B3) 00 00 00 00 00 Frame Memory
reg(0x00B4) 00 00 Frame Mode
reg(0x00B6) 00 00 00 00 00 Display Control
reg(0x00B7) 00 00 Entry Mode Set
reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B
reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control
reg(0x00C1) 00 00 00 00 Display Timing
reg(0x00C5) 00 00 Frame Rate
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
reg(0x00CC) 00 00 Panel Control
reg(0x00D0) 00 00 00 00 Power Control
reg(0x00D1) 00 00 00 00 VCOM Control
reg(0x00D2) 00 00 00 Power Normal
reg(0x00D3) 00 00 00 00 ILI9341, ILI9488
reg(0x00D4) 00 00 00 00 Novatek
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P
reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N
reg(0x00EF) 00 00 00 00 00 00 ILI9327
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
ILI9486 / 1LI9488
reg(0x0005) 00 00 DSI errors
reg(0x000B) 00 00 Get Address Mode
reg(0x000D) 00 00 Get Display Mode
reg(0x000E) 00 00 Get Signal Mode
reg(0x000F) 00 00 Get Diagnostic Result
reg(0x00B0) 00 00 Interface Mode
reg(0x00B1) 00 00 00 Frame Rate Normal
reg(0x00B2) 00 00 00 Frame Rate Idle
reg(0x00B3) 00 00 00 Frame Rate Partial
reg(0x00B4) 00 00 Inversion Control
reg(0x00B5) 00 00 00 00 00 Blanking Porch
reg(0x00B6) 00 00 00 00 Display Control
reg(0x00BF) 00 00 00 00 00 00 NON-Ilitek Device Code Read
reg(0x00C0) 00 00 00 Power Control 1
reg(0x00C1) 00 00 00 Power Control 2
reg(0x00C2) 00 00 Power Control 3
reg(0x00C3) 00 00 Power Control 4
reg(0x00C4) 00 00 Power Control 5
reg(0x00C5) 00 00 00 00 00 VCOM Control 1
reg(0x00D3) 00 00 00 00 RDID4
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 Adjust 2
reg(0x00F7) 00 00 00 00 00 Adjust 3
reg(0x00F8) 00 00 00 Adjust 4
reg(0x00F9) 00 00 00 Adjust 5
reg(0x00FB) 00 00 SPI Read
reg(0x00FC) 00 00 00 Adjust 6
can someone help me figure out the problem?
