3.6v 2.0a stepping motor to arduino
Hi! I'm trying to connect my stepping motor to arduino
What I have a stepping motor like this
Step angle : 1.8˚
Rated Voltage : 3.6V
Rated Current : 2.0A
Holding Torque : 8500 gf-cm
and I have easy driver and 12V 1.3A adaptor
It could be a stupid question
but, I don't have any knowledge of voltage and power... so..
Is it possible to connect those?
or do I need another equipments?
thanks!
Have a look at Stepper Motor Basics
An Easydriver can only supply a max of 750mA whereas your motor requires 2000mA.
You might get away with using a Pololu DRV8825 with a heatsink and maybe a cooling fan. However if it was my project I would like a stepper driver that could handle 3 or 4 amps - and they are a lot more expensive.
Note that the rated voltage is essentially irrelevant. The important thing is the motor current.
...R
Simple Stepper Code
What are you trying to do with the motor?
