3.7v LiPo readings is Correct?
For that i buy multimeter. And this is the first multimeter i own LoL. The thing is now i have problem with the readings, do you know how to read millivolts? The multimeter model is DT-830B
Sorry for that :frowning:
21 posts and I still cannot figure out how you connected the battery
Ve+ to 5v pin (split to A0 pin for measuring)
Ve- to GND pin
I have 2 issues with that,
  1. nano is 5v board which you power with 3.7v.
  2. you shorted 5v pin with A0, and you are comparing v on A0 practically to v on 5v pin, what exactly you expect the result would be?
I was trying to use this sketch, for my understanding the analogRead(A0) is a spliting Ve+ to wired to A0 pin
Battery Level Check using Arduino - #8 by kmikulec
  1. Plug the black wire into COM.
  2. Plug the red wire into V[Ohm]mA
  3. Turn the knob to DCV 2000m
  4. Put the black probe on Ground
  5. Put the red probe on the Aref pin
  6. Read the meter display
Thanks a lot
p/s: i just found out how to reply with a quote LoL
It doesn’t tell you what board the code is for, what analog reference is set or how it is even connected to the board. There are no follow ups either and not a single confirmation that it actually works
I run a test just now to disconnect the wire from A0 pin, and the result is the voltage now is 0.00v (not reading anything). So the code is working when Ve+ connect to A0 pin. And my only problem now is somewhere on (3.6, 4.2, 0,200) line to display to correct (atleast) battery to show.
I'm sorry I just dont know how else to explain that you need reference voltage independent of battery current potential, so you could compare the change in battery potential to that voltage. Otherwise your battery will always show 100%
Okay this is mind bending, tested on 2 arduino nano. 1 already wired to other sensors, 1 not wire to anything.
Both i get reading 002, i assume there is nothing wrong with the boards.
So, the arduino is powered from the battery which is connected to 5V & GND. Then there is a wire from 5V/Batt+ to A0 and you expect to be able to read the voltage from A0? That's not gonna work for you. The arduino uses the supply-voltage as reference (which can be read with a DMM on the ARef pin) in order to compare other voltages to the reference. In your case the reference voltage is always equal to the voltage supplied to A0 and thus the reading will always be the same. You are in other words comparing a voltage to itself.
Did you by chance try the code I linked to in reply #4? That code will compare the analog reference voltage to the internal reference voltage and give you a very good reading of the supply voltage. If you did not try that code, it seems like you do not want to solve your problem.
Yes im taking readings from A0 pin. And i think i got it right just now. Will monitor it and update later if its correct or just a placebo
How is your current wiring?
If you are reading 2 millivolts on the Aref pin when you run the sketch and send an R with Serial Monitor then something is very wrong with both of your Nanos or your meter. Before you send the R, the voltage on Aref should be about 5V (or 3.3v if you are using a 3.3V Nano).
Try the meter to "20" and read 5v its normal i get 4.88-4.99v
Same as above
Or maybe because i connect the battery to TP4056 before it connect to the board?
can you quote in full what you are replying to instead of unhelpful one word quotes? thanks
Sorry for that, im new here and many function of the forum is new to me :frowning:
Beside of the code i share here, can you help pointing me any code/sketch on how to monitor 3.7v battery actually is? Or is it cannot be monitored?
