I am trying to put a 3.97" TFT display - 3.97inch 16BIT Module OTM8009A SKU:MRB3971 - LCD wiki - wired to a Arduino DUE exactly as described in GxIO_DUE_P16_WIRED.cpp from GxTFT library but even after many days working over it the display still off & black !!! I really do not know what is happening. I will thanks forever if someone would give me any help.
The connection made are:
DUE PIN TFT PIN
31 (A7) ------ D15
33 (C1) ------ D14
35 (C3) ------ D13
37 (C5) ------ D12
39 (C7) ------ D11
41 (C9) ------ D10
43 (C20) ------ D9
45 (C18) ------ D8
38 (C6) ------ D7
40 (C8) ------ D6
42 (A19) ------ D5
44 (C19) ------ D4
46 (C17) ------ D3
48 (C15) ------ D2
50 (C13) ------ D1
52 (B21) ------ D0
29 (D6) ------ CS
51 (C12) ------ RS
25 (D0) ------ RST
49 (C14) ------ WR
47 (C16) ------ RD
23 (A14) ------ BL
GND ------ GND
+5v ------ +5V
The initial lines of my test program is:
#include <GxTFT_GFX.h>
#define TFT_Class GxTFT_GFX
#include <GxIO/GxIO_DUE_P16_WIRED/GxIO_DUE_P16_WIRED.h>
#include <GxCTRL/GxCTRL_OTM8009A/GxCTRL_OTM8009A.h>
GxIO_Class io; // #define GxIO_Class is in the selected header file
GxCTRL_Class controller(io); // #define GxCTRL_Class is in the selected header file
TFT_Class tft(io, controller, 800, 480); // landscape 800x480 7inch Display
#include "GxReadRegisters.h"
The printed result is: (with display always black):
GxCTRL_OTM8009A Test on GxIO_DUE_P16_WIRED
tft.init() done
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 00 00 00 00 00 Status Register
reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B
reg(0x00D3) 00 00 00 00 ILI9341, ILI9488
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P
reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N
reg(0x000A) 00 00 Get Power Mode
reg(0x000C) 00 00 Get Pixel Format
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B4) 00 00 Inversion Control
reg(0x00B6) 00 00 00 00 00 Display Control
reg(0x00B7) 00 00 Entry Mode Set
reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control
reg(0x00CC) 00 00 Panel Control
reg(0x00D0) 00 00 00 Power Control
reg(0x00D2) 00 00 00 00 00 NVM Read
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00EF) 00 00 00 00 00 00 ILI9327
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
0x0 0x0 0x0 0x0
0x0 0x0 0x0 0x0
0x0 0x0 0x0 0x0
0x0 0x0 0x0 0x0
Benchmark Time (microseconds)
Screen fill 8697089
Text 387881
Lines 10505443
Horiz/Vert Lines 797173
Rectangles (outline) 428193
Rectangles (filled) 28364676
Circles (filled) 4881513
Circles (outline) 9429409
Triangles (outline) 1906960
Triangles (filled) 11229086
Rounded rects (outline) 2521605
Rounded rects (filled) 29305972
Done!
This long time taken for easy functins is very curious !!!
Thanks again.
