Hey Guys,
So I'm a bit new to sensors and I'm doing a school project on this MMA7455 tilt sensor that I have recently set up from the following site: https://arduino-info.wikispaces.com/accelerometer-MMA7455?responseToken=018173f92ea03de7e0011a7d7c983677
However, the teacher needs something unique rather than a simple code to make it just work. If they're any suggestions on what I can do with the sensor, that will be much appreciated.
I have an idea of when the tilt occurs either forward or backwards or left or right there can be a led lighting up followed by a beep (different frequency of beeps from a piezo speaker); however, i need help setting up the code for this. If anyone can help or any other ideas that will be nice.
Here is the code so far that i used to calibrate the sensor with:
/*-----( Import needed libraries )-----*/
#include <Wire.h> //Include the Wire library
#include <MMA_7455.h> //Include the MMA_7455 library
/*-----( Declare Constants and Pin Numbers )-----*/
/*-----( Declare objects )-----*/
MMA_7455 mySensor = MMA_7455(); //Make an instance of MMA_7455
/*-----( Declare Variables )-----*/
char xVal, yVal, zVal; //Variables for the values from the sensor
void setup() /****** SETUP: RUNS ONCE ******/
Serial.println("MMA7455 Accelerometer Test. terry@yourduino.com");
// Set the sensitivity you want to use
// 2 = 2g, 4 = 4g, 8 = 8g
mySensor.initSensitivity(2); // Good for "Tilt" measurements
/* Calibrate the Offset. Calibrate, in Flat position, try to
get: xVal = 0, yVal = 0, zVal = +63 (1 G)
!!!Activate this after having the first values read out!!!
Suggestion: Run this with offsets = 0,0,0 and see needed correction
// mySensor.calibrateOffset(0,0,0); //Uncomment for first try: find offsets
// mySensor.calibrateOffset(-5.0, 13.0, -12.0); //Then Uncomment and use this
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
xVal = mySensor.readAxis('x'); //Read out the 'x' Axis
yVal = mySensor.readAxis('y'); //Read out the 'y' Axis
zVal = mySensor.readAxis('z'); //Read out the 'z' Axis
Serial.print("X = ");
Serial.print(xVal, DEC);
Serial.print(" Y = ");
Serial.print(yVal, DEC);
Serial.print(" Z = ");
Serial.println(zVal, DEC);
/*--( Show tilt [Assumes unit has been calibrated ] )----*/
if (xVal < -20) Serial.println("Tilted LEFT");
if (xVal > 20) Serial.println("Tilted RIGHT");
if (yVal < -20) Serial.println("Tilted TOWARDS");
if (yVal > 20 ) Serial.println("Tilted AWAY");
if (zVal < -45 ) Serial.println("UPSIDE DOWN!");
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//*********( THE END )***********
Thank You.
