3 axis data confusion
Hi, I recently just got my 3 axis accelerometer, the MMA7361 from Sparkfun; datasheet(http://www.sparkfun.com/datasheets/Components/General/MMA7361L.pdf) and I soldered all the connecters to pins (i forgot what it’s called). Anyway, I wrote a code to see if the accelerometer works. But my problem is that I keep getting numbers that don’t change much even if I give it a sudden acceleration. Feel free to alter the code and please give me some advice on how to make this better. I also added a snippet of my results. Thanks
int x_axis = 0;
int y_axis = 1;
int z_axis = 2;
int x_result;
int y_result;
int z_result;
int sleep = 2;
int g_select = 4;
void setup ()
  digitalWrite(sleep, HIGH);
  digitalWrite(g_select, HIGH);
void loop ()
  int x_result = analogRead(x_axis);
  int y_result = analogRead(y_axis);
  int z_result = analogRead(z_axis);
  Serial.print(x_result);
  Serial.print(" ");
  Serial.print(y_result);
  Serial.print(" ");
  Serial.print(z_axis);
Results: (flat on table)
342 341 2
343 341 2
343 341 2
343 342 2
342 341 2
342 341 2
343 341 2
342 341 2
343 341 2
343 341 2
342 340 2
342 341 2
343 341 2
343 340 2
343 341 2
342 340 2
The numbers won't change much if you only print them out twice a second.
What happens if you align the different axes with Z (downwards)? Do the results agree with each other?
int z_axis = 2;
Hmmmm.
Thanks for the reply! I changed the sampling rate to 100 milliseconds and my results show more changes when i move it so thats fixed but the Z axis is still two. I tried switching cables (x cable goes in to z) but the results are still the same.
Yes, Z will always be two.
Before you write a pin HIGH, best make sure it is an output first.
Ok thanks. Anyway, when I replied your first comment, sorry if I was telling you something completely different cause my computer didn't load the quotes and I thought you meant something else. Anyway, I fixed the issue and the Z axis is sending out signals properly. Thank you so much!
Results: (after changes)
340 341 376 340 342 376 340 341 376 340 342 376 340 341 376 340 341 375 340 341 376 340 341 376 340 341 376 340 342 375 339 341 376 340 341 376 340 342 376 340 342 376 339 341 376 340 342 376
