3 axis sensor results to graph
Hello,
I have a 3 axis sensor, I wrote a code that works but it shows me the result into a table, do you know how I can put it on live to a graph?
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
Adafruit_MMA8451 mma = Adafruit_MMA8451();
void setup(void) {
  Serial.println("Adafruit MMA8451 test!");
  if (! mma.begin()) {
    Serial.println("Couldnt start");
    while (1);
  Serial.println("MMA8451 found!");
  mma.setRange(MMA8451_RANGE_2_G);
  Serial.print("Range = "); Serial.print(2 << mma.getRange());
  Serial.println("G");
  // Read the 'raw' data in 14-bit counts
  mma.read();
  Serial.print("X:\t"); Serial.print(mma.x);
  Serial.print("\tY:\t"); Serial.print(mma.y);
  Serial.print("\tZ:\t"); Serial.print(mma.z);
  /* Get a new sensor event */
  sensors_event_t event;
  mma.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("X: \t"); Serial.print(event.acceleration.x); Serial.print("\t");
  Serial.print("Y: \t"); Serial.print(event.acceleration.y); Serial.print("\t");
  Serial.print("Z: \t"); Serial.print(event.acceleration.z); Serial.print("\t");
  Serial.println("m/s^2 ");
  /* Get the orientation of the sensor */
  uint8_t o = mma.getOrientation();
  switch (o) {
    case MMA8451_PL_PUF:
      Serial.println("Portrait Up Front");
    case MMA8451_PL_PUB:
      Serial.println("Portrait Up Back");
    case MMA8451_PL_PDF:
      Serial.println("Portrait Down Front");
    case MMA8451_PL_PDB:
      Serial.println("Portrait Down Back");
    case MMA8451_PL_LRF:
      Serial.println("Landscape Right Front");
    case MMA8451_PL_LRB:
      Serial.println("Landscape Right Back");
    case MMA8451_PL_LLF:
      Serial.println("Landscape Left Front");
    case MMA8451_PL_LLB:
      Serial.println("Landscape Left Back");
  Serial.println(analogRead(A0));
  delay(3);
I have the arduino uno and the mma8451 sensor
Use the free macro PLX-DAQ from Parallax on older versions of Excel.
