3-bit binary counter using LEDs
Hello guys , I have been working on the 3-bit binary counter using LEDs for sometime now. Can you suggest changes to this code as it does not produce an output as of now or can you give me a better code to get the desired output ?
int led2 = 5;
int led1 = 4;
int led0 = 3;
pinMode(led0, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
reset();
for(int i = 0; i < 8; ++i)
signal( led2, ((i >> 2) % 2) == 1);
signal( led1, ((i >> 1) % 2) == 1);
signal( led0, ((i >> 0) % 2) == 1);
delay(2000);
void reset()
signal( led2, 0);
signal( led1, 0);
signal( led0, 0);
void signal(int led, bool on)
if(on)
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
Are you certain your leds are wired correctly?
When I run your sketch with some serial debuging prints, the sketch looks like it should be working properly.
int led2 = 5;
int led1 = 4;
int led0 = 3;
  reset();
  for (int i = 0; i < 8; ++i)
    Serial.print("index ");
    Serial.println(i);
    delay(2000);
void reset()
  Serial.println("reset");
  signal( led2, 0);
  signal( led1, 0);
  signal( led0, 0);
  if (on)
    Serial.println(" on");
    Serial.println(" off");
Why not write the for loop to reflect what you really want:
for( int i = 0; i < 8; i++ ) {
    signal( led2, i >> 2 );
    signal( led1, (i >> 1) & 1 );
    signal( led0, i & 1 );
    delay(2000);
