I have a X-Carve CNC Router, that uses an Arduino Uno and a GShield card.
I have used this for a time with no issues. The other day I came back to the PC after being away from it for a few minutes. The program I use to upload G-code to the Arduino is UGCS. UGCS had a bunch of garbage characters on the screen.
I restarted the program, and have no function from the X-Carve anymore. I noticed the GShield lights for the 3 axis were remaining lit. Usually they light up when each axis operates.
I check out the Arduino as best I could. Everything functioned fine, except I can't reupload GRBL to the Arduino!
When I try to use everything as I had been, everything seems to work til I send code to run the machine.When I link to the Arduino with UGCS it acknowledges connection with the prompt "GRBL 9.0" as it should. I then send code, it appears as if it goes, but I receive no Acknowledgement back..as with the "OK" I usually get.
With everything off, I can push the axis and the appropriate light will lit on the GShield. As I said, I have used this before with no trouble, up til the garbage text on the UGCS screen.
