I need to know if this is possible and what would I need to buy.
I own the arduino uno.
This is for an interactive installation, when a guest sees button 1 blinking they press it button will stay lit, when audio is done button 2 starts to blink, same with 3 then starts over, but if no-one has press a button on 2 or 3 after 3minutes it will reset to 1.
Has anyone done this or working on this that can help me?
What do I need and I also need help with the programming code.
If you get the Wave Shield (audio file player hardware for the Arduino) the programming will be fairly easy.
Draw out a "state machine". In each state certain inputs will change to a new state:
1: LED 1 is blinking
if Button 1 is pressed, start playing Audio 1 and go to State 2
2: LED 1 is steady and Audio 1 is playing
When Audio 1 is done, start the 3-minute timer and go to State 3
3: LED 2 is blinking
if Button 2 is pressed, go to State 4
if 3 minutes elapses, got to State 1
4: LED2 is steady...
Tell me about it. My personal project right now is to find a way to use an ipod shuffle in an alarm clock+sound machine I'm designing. Love the small size and big capacity. Hate the interface differences. I'll likely just find a 2nd gen nano to do just that. The only thing I'd say is that in MY project, if it goes wrong, I can just reboot the sucker - no public exposure
The Sparkfun unit really seems to be simple and reliable.
$10 plus whatever small SD card you have laying around.
Played with it for a few minutes and it works AMAZING. Here's a complete sketch:
// initialize the serial communication:
Serial.begin(4800); //Set to 4800 bps
Serial.print(0xEF, BYTE); // Reset board
delay(2000);
Serial.print(1, BYTE); // Play first file
delay(5000);
Serial.print(15, BYTE); // Play second file
delay(8000);
Serial.print(0xEB, BYTE); // Suspend playing
delay(3000);
Serial.print(0xEC, BYTE); // Resume playing
delay(8000);
The "datasheet" at mdfly is ABSURDLY incomplete. To get the GOOD one, google "TDB380 pdf"
You can also use it as a dedicated MP3 player with no microcontroller by just soldering a couple pads and attaching some buttons. Best piece of kit I've found under $100 by far.
I'm planning on using the TDB380 for my own project. Just ordered a couple from MDFLY last night to try out. One question I have is the MDFLY site seems to indicate the minimum input voltage is 6V, but the "good" PDF for the TBD380 is unclear... It says in one place anything from 5V to 30V will work, but in another place it says 6V min. Actually it says both of those on page 2 of this PDF:
So... my question is, can I power this thing from the 5V pin off the Arduino Uno? Or should I be doing some sort of dc dc converter or booster or something?
