3 minutes timer
I'm trying to light a led using bluetooth and then have it on for 3 minutes, then turn off. The problem is with the "timer", it dosen't turn off after 3 minutes (180000ms). Can anyone se what i'm doing wrong? I have just started programming so please be nice :slight_smile:
int LED = 13;
int timer = 180000;
boolean offswitch = true;
unsigned long previousMillis = 0;
  pinMode(LED, OUTPUT);
  if(Serial.available() > 0){
    char data = Serial.read();
    if (data == 'a'){
      digitalWrite(LED, HIGH);
      offswitch = false;
  if (offswitch == false){
    if (currentMillis - previousMillis > timer){
      digitalWrite(LED, LOW);
      offswitch = true;
Make timer unsigned long. 180K won’t fit in an int.
Thank you!!
But now i have another problem.... The problem is that if 'a' is pressed after, for example, 10 seconds. The LED will be light off after 2 minutes and 50 seconds. How do i fix that?
When you turn the led on, set previousmillis to millis()
Thank you so much again!!
