Hi guys !
I’ve got 3 nanos (clone) and 4 i2C devices (2 BMP180, 2 OLED 32x128), but still, after trying everything, from changing IDE to multimeter tests, I’ve still got issues.
None of my nanos / i2c devices recognized themselves. Every ones used to work a week ago. Tested multiple ways.
I’m using this code to find i2c, nothing gives (No devices found)
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
Serial.begin (115200);
// Leonardo: wait for serial port to connect
// while (!Serial)
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 1; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
void loop() {}
For BMP180 and OLED display, I use the provided examples (which worked earlier)
I’ve no idea what’s doing it. I tried with Create.Arduino.CC, with the offline IDE (it could have been a library issue with the offline IDE, as I’ve been messing with duplicates around projects).
I’m wiring my (5v compliant) i2c devices right, SDA to A4, SCL to A5, GND well, VCC to 5V
None of the pins are shorted
Thanks a lot
EDIT : Wired on Breadboard, I’ve tried with USB, and an external 5V supply (bb supply)
EDIT 2: everything else works; pins A4 and A5 are usable as outputs fine. Uploading is OK. Only I2C is messing up
