I have two brs368h130abb motors they are 3 phase steppers, in the casing I see 3 connectors, each seams to be internally soldered to 2 wires.
I Need to drive this motors.
What driver schematics do I need and what voltages, can i drive it only with mosfets and some pattern 100 010 001 ... or does this motor type needs analog voltages?
I don't think this is a stepper motor. The diagram seems to indicate that it is a delta wound 3 phase motor. The diagram agrees with your description. There is probably a good reason you couldn't find reference to 3 phase steppers.
To satisfy my curiosity I looked further and finally found some delta wound steppers instead of the wye configuration. NONE of the spec sheets said much about how to drive them. There were references to control chips so you might search that term and see if you can find what you need.
Yes, there is no huge distinction between a 3-phase brushless motor and a 3-phase stepper motor and a 3-phase permanent
magnet AC motor - steppers conventionally have a lot more effective poles via the toothed-pole profile trick, but they will
all respond to a 3-phase drive signal by turning.
These motors definitely fall in the stepper category with the step angles quoted.
