3 programmes ensembles
j'ai trois progammes a faire fonctionnner ensemble
#include <TFT.h>
#include <SPI.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Wire.h>
float current;
int termPin = 6;  //termistor pin connection
int termNom = 100000;   //resistancve du termistor
int refTemp = 25;    //
int beta = 3950;
int resistance = 100000; // valeure resistance serie
#define cs 10
#define dc 9
#define rst 8
TFT TFTscreen = TFT(cs, dc, rst);
//#include <TinyGPS++.h>
//#include <SoftwareSerial.h>
//#include <SPI.h>
//#include <Wire.h>
//#include <Adafruit_GFX.h>
//#include <Adafruit_SSD1306.h>
//:Adafruit_SSD1306 display(0) ;
//#define SCREEN_WIDTH 128
//#define SCREEN_HEIGHT 64
//#define OLED_RESET   4
//#define SCREEN_ADRESS 0x3C
//Adafruit_SSD1306  display(SCREEN_WIDTH, SCREEN_HEIGHT, &WIRE, OLED_RESET);
//unsigned int mesure;
//float Mesuretension ;
//float tension ;
const int RXPin = 2 , TXPin = 3 ;
const uint32_t GPSBaud = 9600; //Default baud of NEO-6M is 9600
TinyGPSPlus gps; // the TinyGPS++ object
SoftwareSerial gpsSerial(RXPin, TXPin);
 //variable
       gpsSerial.begin(GPSBaud);
  TFTscreen.begin();
  //TFTscreen.setRotation(270);
  TFTscreen.background(0,2,250);
    if (gpsSerial.available() > 0) {
    if (gps.encode(gpsSerial.read())) {
        TFTscreen.stroke(230, 60, 20) ;
        TFTscreen.textSize(5) ;
        TFTscreen.setCursor (10,5) ;
        TFTscreen.print(gps.speed.kmph());
      //display.clearDisplay () ;
      //(gps.speed.kmph());
        TFTscreen.textSize(2) ;
        TFTscreen.setCursor (20,55) ;
        TFTscreen.print(gps.time.hour() +1 );
        TFTscreen.print(F(":"));
        TFTscreen.print(gps.time.minute());
        TFTscreen.println(gps.time.second());
       // delay (3000) ;
       // TFTscreen.background(0,2,250);
      current = analogRead(termPin);
      current = 1023 / current - 1;
      current = resistance / current;
      float temperature;
      temperature = current / termNom;
      temperature = log(temperature);
      temperature /= beta;
      temperature += 1.0 / (refTemp + 273.15);
      temperature = 1.0 / temperature;
      temperature -= 273.15;
             //  display.setTextSize (3) ;
               //display.setCursor ( 0,5) ;
               TFTscreen.setCursor (10,100) ;
               TFTscreen.print(temperature,1);
               //display.display () ;
               //delay (2000);
     delay (3000) ;
Tachometer using micros
On this sketch we are going to measure the period between pulses using the micros() function to get the RPM
(Revolutions Per Minute) from a sensor on pin 2.
This way of measuring RPM makes it accurate, responsive and versatile. No matter how fast or slow the loop is
running, the reading accuracy is not going to be affected. Although, the faster you run the loop, the more amount
of readings you are going to be able to display every second.
It's coded in a way that the micros rollover doesn't create glitches every 71 minutes, so it can run forever
without problems.
We use an interrupt for the input so you have to choose pin 2 or 3 (for Arduino Uno/nano). In this example we
use pin 2.
/////// OLED 0.96" Display:
We are going to use the OLED 128x64 I2C with SSD1306 driver using the Adafruit library.
Pins for OLED display and arduino uno/nano:
 * GND = GND
 * VCC = 5V
 * SCL = A5
 * SDA = A4
It's a good idea to put a resistor between A4-5V and A5-5V to help stabilize the connection.
What that does is pull-up the I2C pins to make it more reliable and prevents lock-ups.
Libraries needed for the OLED display:
https://github.com/adafruit/Adafruit_SSD1306
https://github.com/adafruit/Adafruit-GFX-Library
This sketch was made for my video tutorial shown here: https://www.youtube.com/watch?v=u2uJMJWsfsg
Made by InterlinkKnight
Last update: 05/23/2019
// Calibration:
const byte PulsesPerRevolution = 2;  // Set how many pulses there are on each revolution. Default: 2.
// If the period between pulses is too high, or even if the pulses stopped, then we would get stuck showing the
// last value instead of a 0. Because of this we are going to set a limit for the maximum period allowed.
// If the period is above this value, the RPM will show as 0.
// The higher the set value, the longer lag/delay will have to sense that pulses stopped, but it will allow readings
// at very low RPM.
// Setting a low value is going to allow the detection of stop situations faster, but it will prevent having low RPM readings.
// The unit is in microseconds.
const unsigned long ZeroTimeout = 100000;  // For high response time, a good value would be 100000.
                                           // For reading very low RPM, a good value would be 300000.
// Calibration for smoothing RPM:
const byte numReadings = 2;  // Number of samples for smoothing. The higher, the more smoothing, but it's going to
                             // react slower to changes. 1 = no smoothing. Default: 2.
// Variables:
volatile unsigned long LastTimeWeMeasured;  // Stores the last time we measured a pulse so we can calculate the period.
volatile unsigned long PeriodBetweenPulses = ZeroTimeout+1000;  // Stores the period between pulses in microseconds.
                       // It has a big number so it doesn't start with 0 which would be interpreted as a high frequency.
volatile unsigned long PeriodAverage = ZeroTimeout+1000;  // Stores the period between pulses in microseconds in total, if we are taking multiple pulses.
unsigned long FrequencyRaw;  // Calculated frequency, based on the period. This has a lot of extra decimals without the decimal point.
unsigned long FrequencyReal;  // Frequency without decimals.
unsigned long RPM;  // Raw RPM without any processing.
unsigned int PulseCounter = 1;  // Counts the amount of pulse readings we took so we can average multiple pulses before calculating the period.
unsigned long PeriodSum; // Stores the summation of all the periods to do the average.
unsigned long LastTimeCycleMeasure = LastTimeWeMeasured;  // Stores the last time we measure a pulse in that cycle.
                                    // We need a variable with a value that is not going to be affected by the interrupt
                                    // because we are going to do math and functions that are going to mess up if the values
                                    // changes in the middle of the cycle.
unsigned long CurrentMicros = micros();  // Stores the micros in that cycle.
// We get the RPM by measuring the time between 2 or more pulses so the following will set how many pulses to
// take before calculating the RPM. 1 would be the minimum giving a result every pulse, which would feel very responsive
// even at very low speeds but also is going to be less accurate at higher speeds.
// With a value around 10 you will get a very accurate result at high speeds, but readings at lower speeds are going to be
// farther from eachother making it less "real time" at those speeds.
// There's a function that will set the value depending on the speed so this is done automatically.
unsigned int AmountOfReadings = 1;
unsigned int ZeroDebouncingExtra;  // Stores the extra value added to the ZeroTimeout to debounce it.
                                   // The ZeroTimeout needs debouncing so when the value is close to the threshold it
                                   // doesn't jump from 0 to the value. This extra value changes the threshold a little
                                   // when we show a 0.
// Variables for smoothing tachometer:
unsigned long readings[numReadings];  // The input.
unsigned long readIndex;  // The index of the current reading.
unsigned long total;  // The running total.
unsigned long average;  // The RPM value after applying the smoothing.
#include <Adafruit_GFX.h>  // Include core graphics library for the display.
#include <Adafruit_SSD1306.h>  // Include Adafruit_SSD1306 library to drive the display.
Adafruit_SSD1306 display(128, 64);  // Create display.
#include <Fonts/FreeMonoBold18pt7b.h>  // Add a custom font.
void setup()  // Start of setup:
  Serial.begin(9600);  // Begin serial communication.
  attachInterrupt(digitalPinToInterrupt(2), Pulse_Event, RISING);  // Enable interruption pin 2 when going from LOW to HIGH.
  delay(1000);  // We sometimes take several readings of the period to average. Since we don't have any readings
                // stored we need a high enough value in micros() so if divided is not going to give negative values.
                // The delay allows the micros() to be high enough for the first few cycles.
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // Initialize display with the I2C address of 0x3C.
  display.clearDisplay();  // Clear the buffer.
  display.setTextColor(WHITE);  // Set color of the text to white.
  display.setRotation(0);  // Set orientation. Goes from 0, 1, 2 or 3.
  display.setTextWrap(false);  // By default, long lines of text are set to automatically “wrap” back to the leftmost column.
                               // To override this behavior (so text will run off the right side of the display - useful for
                               // scrolling marquee effects), use setTextWrap(false). The normal wrapping behavior is restored
                               // with setTextWrap(true).
  display.dim(0);  // Set brightness (0 is maximum and 1 is a little dim).
}  // End of setup.
void loop()  // Start of loop:
  // The following is going to store the two values that might change in the middle of the cycle.
  // We are going to do math and functions with those values and they can create glitches if they change in the
  // middle of the cycle.
  LastTimeCycleMeasure = LastTimeWeMeasured;  // Store the LastTimeWeMeasured in a variable.
  CurrentMicros = micros();  // Store the micros() in a variable.
  // CurrentMicros should always be higher than LastTimeWeMeasured, but in rare occasions that's not true.
  // I'm not sure why this happens, but my solution is to compare both and if CurrentMicros is lower than
  // LastTimeCycleMeasure I set it as the CurrentMicros.
  // The need of fixing this is that we later use this information to see if pulses stopped.
  if(CurrentMicros < LastTimeCycleMeasure)
    LastTimeCycleMeasure = CurrentMicros;
  // Calculate the frequency:
  FrequencyRaw = 10000000000 / PeriodAverage;  // Calculate the frequency using the period between pulses.
  // Detect if pulses stopped or frequency is too low, so we can show 0 Frequency:
  if(PeriodBetweenPulses > ZeroTimeout - ZeroDebouncingExtra || CurrentMicros - LastTimeCycleMeasure > ZeroTimeout - ZeroDebouncingExtra)
  {  // If the pulses are too far apart that we reached the timeout for zero:
    FrequencyRaw = 0;  // Set frequency as 0.
    ZeroDebouncingExtra = 2000;  // Change the threshold a little so it doesn't bounce.
    ZeroDebouncingExtra = 0;  // Reset the threshold to the normal value so it doesn't bounce.
  FrequencyReal = FrequencyRaw / 10000;  // Get frequency without decimals.
                                          // This is not used to calculate RPM but we remove the decimals just in case
                                          // you want to print it.
  // Calculate the RPM:
  RPM = FrequencyRaw / PulsesPerRevolution * 60;  // Frequency divided by amount of pulses per revolution multiply by
                                                  // 60 seconds to get minutes.
  RPM = RPM / 10000;  // Remove the decimals.
  // Smoothing RPM:
  total = total - readings[readIndex];  // Advance to the next position in the array.
  readings[readIndex] = RPM;  // Takes the value that we are going to smooth.
  total = total + readings[readIndex];  // Add the reading to the total.
  readIndex = readIndex + 1;  // Advance to the next position in the array.
  if (readIndex >= numReadings)  // If we're at the end of the array:
    readIndex = 0;  // Reset array index.
  // Calculate the average:
  average = total / numReadings;  // The average value it's the smoothed result.
  // Print information on the serial monitor:
  // Comment this section if you have a display and you don't need to monitor the values on the serial monitor.
  // This is because disabling this section would make the loop run faster.
  Serial.print("Period: ");
  Serial.print(PeriodBetweenPulses);
  Serial.print("\tReadings: ");
  Serial.print(AmountOfReadings);
  Serial.print("\tFrequency: ");
  Serial.print(FrequencyReal);
  Serial.print("\tRPM: ");
  Serial.print(RPM);
  Serial.print("\tTachometer: ");
  Serial.println(average);
  // Convert variable into a string, so we can change the text alignment to the right:
  // It can be also used to add or remove decimal numbers.
  char string[10];  // Create a character array of 10 characters
  // Convert float to a string:
  dtostrf(average, 6, 0, string);  // (<variable>,<amount of digits we are going to use>,<amount of decimal digits>,<string name>)
  display.clearDisplay();  // Clear the display so we can refresh.
  display.setFont(&FreeMonoBold18pt7b);  // Set a custom font.
  display.setTextSize(0);  // Set text size. We are using a custom font so you should always use the text size of 0.
  display.setCursor(0, 25);  // (x,y).
  display.println("RPM:");  // Text or value to print.
  // Print variable with right alignment:
  display.setCursor(0, 60);  // (x,y).
  display.println(string);  // Text or value to print.
  // Print a comma for the thousands separator:
  if(average > 999)  // If value is above 999:
    // Draw line (to show a comma):
    display.drawLine(63, 60, 61, 65, WHITE);  // Draw line (x0,y0,x1,y1,color).
  display.display();  // Print everything we set previously.
}  // End of loop.
void Pulse_Event()  // The interrupt runs this to calculate the period between pulses:
  PeriodBetweenPulses = micros() - LastTimeWeMeasured;  // Current "micros" minus the old "micros" when the last pulse happens.
                                                        // This will result with the period (microseconds) between both pulses.
                                                        // The way is made, the overflow of the "micros" is not going to cause any issue.
  LastTimeWeMeasured = micros();  // Stores the current micros so the next time we have a pulse we would have something to compare with.
  if(PulseCounter >= AmountOfReadings)  // If counter for amount of readings reach the set limit:
    PeriodAverage = PeriodSum / AmountOfReadings;  // Calculate the final period dividing the sum of all readings by the
                                                   // amount of readings to get the average.
    PulseCounter = 1;  // Reset the counter to start over. The reset value is 1 because its the minimum setting allowed (1 reading).
    PeriodSum = PeriodBetweenPulses;  // Reset PeriodSum to start a new averaging operation.
    // Change the amount of readings depending on the period between pulses.
    // To be very responsive, ideally we should read every pulse. The problem is that at higher speeds the period gets
    // too low decreasing the accuracy. To get more accurate readings at higher speeds we should get multiple pulses and
    // average the period, but if we do that at lower speeds then we would have readings too far apart (laggy or sluggish).
    // To have both advantages at different speeds, we will change the amount of readings depending on the period between pulses.
    // Remap period to the amount of readings:
    int RemapedAmountOfReadings = map(PeriodBetweenPulses, 40000, 5000, 1, 10);  // Remap the period range to the reading range.
    // 1st value is what are we going to remap. In this case is the PeriodBetweenPulses.
    // 2nd value is the period value when we are going to have only 1 reading. The higher it is, the lower RPM has to be to reach 1 reading.
    // 3rd value is the period value when we are going to have 10 readings. The higher it is, the lower RPM has to be to reach 10 readings.
    // 4th and 5th values are the amount of readings range.
    RemapedAmountOfReadings = constrain(RemapedAmountOfReadings, 1, 10);  // Constrain the value so it doesn't go below or above the limits.
    AmountOfReadings = RemapedAmountOfReadings;  // Set amount of readings as the remaped value.
    PulseCounter++;  // Increase the counter for amount of readings by 1.
    PeriodSum = PeriodSum + PeriodBetweenPulses;  // Add the periods so later we can average.
}  // End of Pulse_Event.
les programme sont un tachymetre un gps vitesse et heure et le troisième
thermometre
C'est un projet intéressant mais votre Post mis dans la mauvaise section, on parle anglais dans les forums généraux. ➜ je l'ai déplacé vers le forum francophone pour vous pour cette fois...
Merci de prendre en compte les recommandations listées dans "Les bonnes pratiques du Forum Francophone”
sinon vous avez une question ?
Ce sujet est abordé plusieurs fois par an et depuis de nombreuses années.
Avec un moteur de recherche, agrémenté ou non d’IA, il devrait être possible de trouver de nombreux tutoriaux.
Un petit effort, merci.
La base de tous les tutoriaux est compréhension des rôles de setup et de loop.
Une fois cette base acquise, ce n’est plus qu’une question de logique vraiment basique.
voiic les 3 programmes ensembles`
// Calibration:
const byte PulsesPerRevolution = 1;  // Set how many pulses there are on each revolution. Default: 2.
// at very low RPM.
// Variables:
#include <TFT.h>
#include <SPI.h>
#include <Wire.h>
float current;
int beta = 3950;
//#define cs 10
//#define dc 9
//#define rst 8
//TFT TFTscreen = TFT(cs, dc, rst);
#include <SPI.h>
#include <Wire.h>
//Adafruit_SSD1306 display(0) ;
//float tension ;
const int RXPin = 4 , TXPin = 3 ;
 //variable
       //gpsSerial.begin(GPSBaud);
  //TFTscreen.begin();
  //TFTscreen.background(0,2,250);
          display.println(gps.speed.kmph());
          delay (3000) ;
             display.println(gps.time.hour() +1 );
             display.println(F(":"));
             display.println(gps.time.minute());
            delay (3000) ;
      float temperature;
               display.println(temperature,1);
               delay (3000) ;
  // Smoothing RPM:
  Serial.print(RPM);
  // End of loop.
et la question est ? (s'i y en a une)
quand je compile j'ai plusieures defaut si vous pouvez me corriger le programme merci
euh... La majorité des aidants ici ne fait pas trop ce genre de choses.
Comprenez vous finement chacun des codes ? c'est nécessaire avant de les mettre ensemble.
Ensuite plutôt que de copier coller tout d'un coup et espérer que ça fonctionne, écrivez votre code en partant de rien (ou d'un des sketch) . Au moins vous maitriserez ce qu'il se passe.
merci
