hello! i’m working on a interactive wall and i need to use a big number of leds an lightresensors. I started puttin g the leds in the 9 10 11 pin (PWM) and i controlled them with lightsensor on digital pins…
here’s my code…
int ledPinC = 11;
int inPinC = 8;
int valueC = 0;
int valC = 0;
int ledPinB = 10;
int inPinB = 7;
int valueB = 0;
int valB = 0;
int ledPinA = 9;
int inPinA = 6;
int valueA = 0;
int valA = 0;
pinMode(ledPinC, OUTPUT); // declare LED as output
pinMode(inPinC, INPUT); // declare pushbutton as input
pinMode(ledPinB, OUTPUT); // declare LED as output
pinMode(inPinB, INPUT); // declare pushbutton as input
pinMode(ledPinA, OUTPUT); // declare LED as output
pinMode(inPinA, INPUT); // declare pushbutton as input
void loop(){
valC = digitalRead(inPinC); // read input value
if (valC == LOW) {
digitalWrite(ledPinC, LOW); // turn LED OFF
if (valC == HIGH) {
for(valueC = 0 ; valueC <= 255; valueC+=5) // fade in (from min to max)
analogWrite(ledPinC, valueC); // sets the value (range from 0 to 255)
delay(15); // waits for 30 milli seconds to see the dimming effect
for(valueC = 255; valueC >=0; valueC-=5) // fade out (from max to min)
delay(15);
valB = digitalRead(inPinB); // read input value
if (valB == LOW) {
digitalWrite(ledPinB, LOW); // turn LED OFF
if (valB == HIGH) {
for(valueB = 0 ; valueB <= 255; valueB+=5) // fade in (from min to max)
analogWrite(ledPinB, valueB); // sets the value (range from 0 to 255)
for(valueB = 255; valueB >=0; valueB-=5) // fade out (from max to min)
delay(15);
valA = digitalRead(inPinA); // read input value
if (valA == LOW) {
digitalWrite(ledPinA, LOW); // turn LED OFF
if (valA == HIGH) {
for(valueA = 0 ; valueA <= 255; valueA+=5) // fade in (from min to max)
analogWrite(ledPinA, valueA); // sets the value (range from 0 to 255)
for(valueA = 255; valueA >=0; valueA-=5) // fade out (from max to min)
delay(15);
NOW: MY QUESTION IS: HOW CAN I MAKE THE LEDS FADE ALL TOGHETER (IF THE 3 LIGHTSENSORS ARE LOW, FOR EXAMPLE)? WITH MY SCRIPT THE LEDS FADE IN AND OUT ONCE AT TIME… BUT NOTHING APPENS DURING A LOOP FADE IN-OUT…
sorry for my bad english… i’m a poor stupid student… and i’m italian… so…
