#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 5 // Configurable, see typical pin layout above
#define SS_1_PIN 22 // Configurable, take a unused pin, only HIGH/LOW required, must be different to SS 2
#define SS_2_PIN 24 // Configurable, take a unused pin, only HIGH/LOW required, must be different to SS 1
#define SS_3_PIN 53
#define NR_OF_READERS 3
byte ssPins[] = {SS_1_PIN, SS_2_PIN, SS_3_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
Serial.print(F("Reader "));
Serial.print(reader);
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
Main loop.
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(": Card UID:"));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
} //if (mfrc522[reader].PICC_IsNewC
} //for(uint8_t reader
Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
I looked at the library code and it doesn't seem to set pinMode() on your CS pins. Pin 53 is the hardware CS pin and is set to OUTPUT for you. Setting it to OUTPUT again won't hurt so I suggest you change:
If the pin is left as an INPUT, setting the output pin to LOW will turn off the internal pull-up resistor. That may be sufficient on some systems to cause the pin to float LOW and select the device. Apparently, that happens on your friend's system but not yours.
