3 servo motors with 3 potentiometers
So can I just copy the basic knob code to the number of motors to the number of corresponding potentiometers?
That should work provided you make appropriate changes to the pin references and code.
Post your code if you want specific advice. (In code tags, please = the # button above the edit window).
...R
FFchocobo:
Yep- I've done it with 2 for an x-y joystick. As Robin2 says, just go through the copied code and change pin numbers, servo names...
Oh, and grow a third arm....
