I am trying to figure out some power issues: i have 3 servos (needing 4,8-6 V), around 25 LEDs (20mA, 3,2 and 1.9 forward V) and 4-5 pressure sensors with variable resistance hooked up to an Arduino Mega…
I use an external power supply for the Arduino board, but after a couple of minutes of running the 3 servos simultaneously they stop running (in MaxMSP they are still sliding, so that's why we are guessing that it is a power issue).
Is it okay to use an external power supply directly connected to the board and set it higher - like 6 V? Or should we use an external battery pack of 6-7,2 V only hooked up to the servos…?
Also i am in doubt about if i could hook up our LEDs (20mA, 3,2 V) in series...the 1,9 V LEDs work fine in series and 5V according to http://led.linear1.org/led.wiz, but the others need higher V, which we do not have now...
Any suggestions would be helpful.
thanks
edit
