3 servos for robot arm interfering big time
Is the Arduino ground directly connected to the servo PSU's GND? Its ambiguous on the diagram.
PeterH:
Hi I'm sorry that is an error in the schematic
The arduino ground pin connects to the ground bus i created.
Its not hooked to GND directly on the PSU even though its really the same thing
its run to the bus
No one has any ideas?
I think your wiring choise is bad. Power your pots from the arduino instead of the servo power supply. Also, putting capacitors on servo motors has yet to solve any servo issues in my experience.
zoomkat:
The pots are reading in nice clean and smooth signals i can watch them on my scope with exactly the values expected. there is no deviation or spikes in the supply as this was the first thing i checked.
Thats not the issue. But thanks for the idea and input its much appreciated.
The pots are reading in nice clean and smooth signals i can watch them on my scope with exactly the values expected. there is no deviation or spikes in the supply as this was the first thing i checked. Thats not the issue.
So you monitored these parameters while the servos are dynamically not acting as expected? Static measurements won't identify the issues. One final thought on "Thats not the issue." You have a lot of stuff that you consider you have done correctly (powersupply, pots, etc), but one or more are not as you think.
What do you mean debug output?
There is no debug output 16 lines of code thats it
By "debug output", I mean getting the sketch to tell you what it knows it is doing, not what you think it should be doing.
Sometimes, the differences in those two outlooks can be quite illuminating.
Try reading reply #14 again.
Shouldn't take long.
Maybe it isn't the issue, but it would be good to eliminate it from inquiries, don't you think?
Do you still get the problem if you have all the servos connected but only move one of them at a time?
Do you still get the problem if you remove the input sensing and move the servos through a predefined sequence of positions?
Electromagnetic interference on the servo control wires seems unlikely to me. I think more likely causes are:
  • floating earth
  • brown-out on a power supply
  • pwm moutput on the Arduino being distorted by something that prevents the timer interrupts from triggering/being handled promptly
  • hardware or logic fault in your sketch causing the sketch to command servo positions which are incorrect. Debug trace output would make this obvious.
What is being asked for is to put serial println statements in so that every pass through loop() you can see what the inputs and outputs are doing. You are assuming that they are correct, but they may not be. Unless you print them out you will never know. It will put out a lot of numbers, but those numbers may have a clue as to what is happening.
You ask for help, the hardware is in your hands and not ours, we need to see some data to make any further suggestions.
I have run 3 servos off an Arduino powered from the USB and had no problem so I am fairly confident that the servo commands work just fine.
What size wire are you using to connect things together?
Hello
Ok here is the latest. Im trying to get everyones answers so you guys can keep assisting me.
Thanks in advance
What i just now is i took out the analog read and ran all 3 servos together. I put it in a loop with the values incrementing and they ran all together with little problem
So with that being said, what does that tell me. Well I'm not really sure.
From what i gather is the following
the Servo map or code is not the issue.
Im either not reading analog values correct--Which i doubt because it works one at a time.
Im not reading analog correct when I'm reading more then one at a time. -- debug report on reads coming in 5 minutes
orrr.............
Any ideas after this development
trying to answer all ur questions
the wire size is actually pretty large. for this project as i usually work with high voltage.
its being done with 20 gauge wire 600v rating 2 amps
Maybe it is your inputs then.
But we won't know until we see the debug output.
Or maybe that's not the issue.
Pot1 = 0 Pot2 = 0 Pot3 = 0
Pot1 = 59 Pot2 = 0 Pot3 = 0
Pot1 = 204 Pot2 = 0 Pot3 = 0
Pot1 = 279 Pot2 = 0 Pot3 = 0
Pot1 = 316 Pot2 = 0 Pot3 = 0
Pot1 = 371 Pot2 = 0 Pot3 = 0
Pot1 = 390 Pot2 = 0 Pot3 = 0
Pot1 = 418 Pot2 = 0 Pot3 = 0
Pot1 = 454 Pot2 = 0 Pot3 = 0
Pot1 = 467 Pot2 = 0 Pot3 = 0
Pot1 = 489 Pot2 = 0 Pot3 = 0
Pot1 = 508 Pot2 = 0 Pot3 = 0
Pot1 = 518 Pot2 = 0 Pot3 = 0
Pot1 = 552 Pot2 = 0 Pot3 = 0
Pot1 = 574 Pot2 = 0 Pot3 = 0
Pot1 = 592 Pot2 = 0 Pot3 = 0
Pot1 = 613 Pot2 = 0 Pot3 = 0
Pot1 = 641 Pot2 = 0 Pot3 = 0
Pot1 = 678 Pot2 = 0 Pot3 = 0
Pot1 = 709 Pot2 = 0 Pot3 = 0
Pot1 = 742 Pot2 = 0 Pot3 = 0
Pot1 = 770 Pot2 = 0 Pot3 = 0
Pot1 = 809 Pot2 = 0 Pot3 = 0
Pot1 = 853 Pot2 = 0 Pot3 = 0
Pot1 = 904 Pot2 = 0 Pot3 = 0
Pot1 = 967 Pot2 = 0 Pot3 = 0
Pot1 = 978 Pot2 = 0 Pot3 = 0
Pot1 = 910 Pot2 = 0 Pot3 = 0
Pot1 = 854 Pot2 = 0 Pot3 = 0
Pot1 = 827 Pot2 = 0 Pot3 = 0
Pot1 = 796 Pot2 = 0 Pot3 = 0
Pot1 = 747 Pot2 = 0 Pot3 = 0
Pot1 = 702 Pot2 = 0 Pot3 = 0
Pot1 = 659 Pot2 = 0 Pot3 = 0
Pot1 = 614 Pot2 = 0 Pot3 = 0
Pot1 = 580 Pot2 = 0 Pot3 = 0
Pot1 = 549 Pot2 = 0 Pot3 = 0
Pot1 = 524 Pot2 = 0 Pot3 = 0
Pot1 = 499 Pot2 = 0 Pot3 = 0
Pot1 = 476 Pot2 = 0 Pot3 = 0
Pot1 = 443 Pot2 = 0 Pot3 = 0
Pot1 = 431 Pot2 = 0 Pot3 = 0
Pot1 = 423 Pot2 = 0 Pot3 = 0
Pot1 = 376 Pot2 = 0 Pot3 = 0
Pot1 = 346 Pot2 = 0 Pot3 = 0
Pot1 = 315 Pot2 = 0 Pot3 = 0
Pot1 = 288 Pot2 = 0 Pot3 = 0
Pot1 = 271 Pot2 = 0 Pot3 = 0
Pot1 = 251 Pot2 = 0 Pot3 = 0
Pot1 = 229 Pot2 = 0 Pot3 = 0
Pot1 = 193 Pot2 = 0 Pot3 = 0
Pot1 = 168 Pot2 = 0 Pot3 = 0
Pot1 = 136 Pot2 = 0 Pot3 = 0
Pot1 = 110 Pot2 = 0 Pot3 = 0
Pot1 = 87 Pot2 = 0 Pot3 = 0
Pot1 = 65 Pot2 = 0 Pot3 = 0
Pot1 = 30 Pot2 = 0 Pot3 = 0
Pot1 = 8 Pot2 = 0 Pot3 = 0
Pot1 = 78 Pot2 = 0 Pot3 = 0
Pot1 = 112 Pot2 = 0 Pot3 = 0
Pot1 = 152 Pot2 = 0 Pot3 = 0
Pot1 = 222 Pot2 = 0 Pot3 = 0
Pot1 = 304 Pot2 = 0 Pot3 = 0
Pot1 = 402 Pot2 = 0 Pot3 = 0
Pot1 = 456 Pot2 = 0 Pot3 = 0
Pot1 = 479 Pot2 = 0 Pot3 = 0
Pot1 = 490 Pot2 = 0 Pot3 = 0
Pot1 = 515 Pot2 = 0 Pot3 = 0
Pot1 = 577 Pot2 = 0 Pot3 = 0
Pot1 = 647 Pot2 = 0 Pot3 = 0
Pot1 = 646 Pot2 = 0 Pot3 = 0
Pot1 = 667 Pot2 = 0 Pot3 = 0
Pot1 = 871 Pot2 = 0 Pot3 = 0
Pot1 = 977 Pot2 = 0 Pot3 = 0
Pot1 = 976 Pot2 = 0 Pot3 = 0
Pot1 = 977 Pot2 = 48 Pot3 = 0
Pot1 = 977 Pot2 = 83 Pot3 = 0
Pot1 = 976 Pot2 = 95 Pot3 = 0
Pot1 = 977 Pot2 = 127 Pot3 = 0
Pot1 = 976 Pot2 = 167 Pot3 = 0
Pot1 = 976 Pot2 = 206 Pot3 = 0
Pot1 = 977 Pot2 = 228 Pot3 = 0
Pot1 = 977 Pot2 = 259 Pot3 = 0
Pot1 = 977 Pot2 = 285 Pot3 = 0
Pot1 = 977 Pot2 = 341 Pot3 = 0
Pot1 = 977 Pot2 = 427 Pot3 = 0
Pot1 = 976 Pot2 = 456 Pot3 = 0
Pot1 = 977 Pot2 = 469 Pot3 = 0
Pot1 = 976 Pot2 = 573 Pot3 = 0
Pot1 = 976 Pot2 = 688 Pot3 = 0
Pot1 = 976 Pot2 = 740 Pot3 = 0
Pot1 = 976 Pot2 = 779 Pot3 = 0
Pot1 = 976 Pot2 = 825 Pot3 = 0
Pot1 = 976 Pot2 = 836 Pot3 = 0
Pot1 = 976 Pot2 = 852 Pot3 = 0
Pot1 = 976 Pot2 = 920 Pot3 = 0
Pot1 = 976 Pot2 = 957 Pot3 = 0
Pot1 = 976 Pot2 = 976 Pot3 = 0
Pot1 = 977 Pot2 = 978 Pot3 = 0
Pot1 = 977 Pot2 = 977 Pot3 = 0
Pot1 = 977 Pot2 = 903 Pot3 = 0
Pot1 = 977 Pot2 = 827 Pot3 = 0
Pot1 = 977 Pot2 = 755 Pot3 = 0
Pot1 = 977 Pot2 = 694 Pot3 = 0
Pot1 = 977 Pot2 = 613 Pot3 = 0
Pot1 = 978 Pot2 = 531 Pot3 = 0
Pot1 = 977 Pot2 = 484 Pot3 = 0
Pot1 = 977 Pot2 = 474 Pot3 = 0
Pot1 = 977 Pot2 = 389 Pot3 = 0
Pot1 = 977 Pot2 = 277 Pot3 = 0
Pot1 = 977 Pot2 = 207 Pot3 = 0
Pot1 = 977 Pot2 = 148 Pot3 = 0
Pot1 = 977 Pot2 = 89 Pot3 = 0
Pot1 = 977 Pot2 = 1 Pot3 = 0
Pot1 = 977 Pot2 = 0 Pot3 = 54
Pot1 = 977 Pot2 = 0 Pot3 = 91
Pot1 = 977 Pot2 = 0 Pot3 = 130
Pot1 = 977 Pot2 = 0 Pot3 = 172
Pot1 = 977 Pot2 = 0 Pot3 = 203
Pot1 = 977 Pot2 = 0 Pot3 = 240
Pot1 = 977 Pot2 = 0 Pot3 = 283
Pot1 = 977 Pot2 = 0 Pot3 = 326
Pot1 = 977 Pot2 = 0 Pot3 = 351
Pot1 = 977 Pot2 = 0 Pot3 = 381
Pot1 = 978 Pot2 = 0 Pot3 = 412
Pot1 = 977 Pot2 = 0 Pot3 = 447
Pot1 = 977 Pot2 = 0 Pot3 = 481
Pot1 = 977 Pot2 = 0 Pot3 = 506
Pot1 = 978 Pot2 = 0 Pot3 = 530
Pot1 = 978 Pot2 = 0 Pot3 = 553
Pot1 = 978 Pot2 = 0 Pot3 = 584
Pot1 = 977 Pot2 = 0 Pot3 = 610
Pot1 = 978 Pot2 = 0 Pot3 = 641
Pot1 = 977 Pot2 = 0 Pot3 = 683
Pot1 = 978 Pot2 = 0 Pot3 = 729
Pot1 = 978 Pot2 = 0 Pot3 = 770
Pot1 = 977 Pot2 = 0 Pot3 = 829
Pot1 = 977 Pot2 = 0 Pot3 = 884
Pot1 = 978 Pot2 = 0 Pot3 = 925
Pot1 = 977 Pot2 = 0 Pot3 = 961
Pot1 = 978 Pot2 = 0 Pot3 = 977
Pot1 = 977 Pot2 = 0 Pot3 = 977
Pot1 = 978 Pot2 = 0 Pot3 = 978
Pot1 = 978 Pot2 = 0 Pot3 = 939
Pot1 = 978 Pot2 = 0 Pot3 = 900
Pot1 = 978 Pot2 = 0 Pot3 = 864
Pot1 = 978 Pot2 = 0 Pot3 = 821
Pot1 = 977 Pot2 = 0 Pot3 = 783
Pot1 = 978 Pot2 = 0 Pot3 = 757
Pot1 = 978 Pot2 = 0 Pot3 = 727
Pot1 = 978 Pot2 = 0 Pot3 = 691
Pot1 = 977 Pot2 = 0 Pot3 = 654
Pot1 = 977 Pot2 = 0 Pot3 = 619
Pot1 = 978 Pot2 = 0 Pot3 = 591
Pot1 = 978 Pot2 = 0 Pot3 = 567
Pot1 = 978 Pot2 = 0 Pot3 = 548
Pot1 = 978 Pot2 = 0 Pot3 = 529
Pot1 = 978 Pot2 = 0 Pot3 = 507
Pot1 = 978 Pot2 = 0 Pot3 = 491
Pot1 = 978 Pot2 = 0 Pot3 = 475
Pot1 = 977 Pot2 = 0 Pot3 = 459
Pot1 = 977 Pot2 = 0 Pot3 = 444
Pot1 = 977 Pot2 = 0 Pot3 = 429
Pot1 = 977 Pot2 = 0 Pot3 = 413
Pot1 = 978 Pot2 = 0 Pot3 = 391
Pot1 = 977 Pot2 = 0 Pot3 = 365
Pot1 = 977 Pot2 = 0 Pot3 = 341
Pot1 = 978 Pot2 = 0 Pot3 = 321
Pot1 = 977 Pot2 = 0 Pot3 = 303
Pot1 = 977 Pot2 = 0 Pot3 = 284
Pot1 = 978 Pot2 = 0 Pot3 = 269
Pot1 = 977 Pot2 = 0 Pot3 = 250
Pot1 = 977 Pot2 = 0 Pot3 = 235
Pot1 = 978 Pot2 = 0 Pot3 = 219
Pot1 = 977 Pot2 = 0 Pot3 = 200
Pot1 = 977 Pot2 = 0 Pot3 = 182
Pot1 = 978 Pot2 = 0 Pot3 = 162
Pot1 = 977 Pot2 = 0 Pot3 = 149
Pot1 = 977 Pot2 = 0 Pot3 = 132
Pot1 = 977 Pot2 = 0 Pot3 = 103
Pot1 = 978 Pot2 = 0 Pot3 = 76
Pot1 = 977 Pot2 = 0 Pot3 = 58
Pot1 = 978 Pot2 = 0 Pot3 = 19
This is a serial read of the pot values
They are as expected
Is this what you refer to as a bug report.
The values coming into arduino are as expected
What makes no sense is they work one at a time.
If there was some major issue in wiring why would they work one at a time?
Thats why im stumped
Who said anything about a bug report?
What were the pots and servos during during that print?
AWOL:
DEBUG OUTPUT!
Sorry
Wrong terminology
Is that not what you wanted. Thats a print of the analog read
Im doing the best i can and i appreciate all the help but if you want something specific please tell me. I will post anything you would like
I have another report for you in one second
Here is some automated code im running now And EVERYTHING works as expected.
The problem lies when i start the analog read
Check this out
#include <Servo.h>
 Servo grip_servo;
 Servo pan_servo;
 Servo tilt_servo;
int pot_grip_pin_value=20;
int pot_pan_pin_value=20;
int pot_tilt_pin_value=20;
int pan_val=0;
int tilt_val=0;
int grip_val=0;
  grip_servo.attach(13);
  pan_servo.attach(2);
  tilt_servo.attach(7);
  //pot_pan_pin_value = analogRead(5);
  //pot_grip_pin_value = analogRead(4);
  //pot_tilt_pin_value = analogRead(3);
  for (int x=0;x<1000;x=x+1){
  if(pan_val<900 && tilt_val<900 && grip_val<900){
        pot_pan_pin_value = map(pan_val, 20, 1000, 20, 150);
        pot_grip_pin_value = map(grip_val, 20, 500, 40, 100);
        pot_tilt_pin_value = map(tilt_val, 200, 1000, 20, 150);
  Serial.print("Pan Value");
  Serial.print("\t");
  Serial.print(pan_val);
  Serial.print("Grip Value");
  Serial.print("\t");
  Serial.print(grip_val);
  Serial.print("tilt Value");
  Serial.print("\t");
  Serial.print(tilt_val);
  Serial.print("\n");
  pan_servo.write(pot_pan_pin_value);
      delay(400);
  grip_servo.write(pot_grip_pin_value);
      delay(400);
  tilt_servo.write(pot_tilt_pin_value);
      delay(4000);
  grip_val = grip_val + 200;
  pan_val = pan_val + 200;
  tilt_val =tilt_val + 200;
  else{
  grip_val=20;
  pan_val=20;
  tilt_val=20;
Im sorry i know its not the best format im trying to do it quickly
Here is a print of it
Pan Value 0 Grip Value 0 tilt Value 0
Pan Value 200 Grip Value 200 tilt Value 200
Pan Value 400 Grip Value 400 tilt Value 400
Pan Value 600 Grip Value 600 tilt Value 600
Pan Value 800 Grip Value 800 tilt Value 800
Pan Value 20 Grip Value 20 tilt Value 20
Pan Value 220 Grip Value 220 tilt Value 220
AWOL:
The pots and servos where being turned manually by my hand
The servos where connected as usual but not in use
I was just reading in values and printing them
Here is another print on the way in 2 seconds of the analog read values while they are actually moving the servos. Lets see if they jump around under load right
check this out
As you guys suspected.
I printed the analog read values under load and normal operation
I moved only ONE POT the one on the far left of the print.
It appears the values of all the other analog reads are moving one i just move one pot while its under load. Some issue perhaps in PSU flucuation under load.
Perhaps i should isolate the pots power source. The board itself should have enough power to give the pot a reference right? There is no load there
Pan Value 977 Grip Value 977 tilt Value 977
Pan Value 843 Grip Value 843 tilt Value 843
Pan Value 903 Grip Value 901 tilt Value 903
Pan Value 904 Grip Value 902 tilt Value 903
Pan Value 904 Grip Value 904 tilt Value 904
Pan Value 906 Grip Value 905 tilt Value 905
Pan Value 902 Grip Value 905 tilt Value 905
Pan Value 905 Grip Value 901 tilt Value 905
Pan Value 906 Grip Value 905 tilt Value 906
Pan Value 906 Grip Value 905 tilt Value 900
Pan Value 906 Grip Value 906 tilt Value 901
Pan Value 906 Grip Value 906 tilt Value 906
Pan Value 901 Grip Value 906 tilt Value 906
Pan Value 900 Grip Value 906 tilt Value 906
Pan Value 906 Grip Value 903 tilt Value 906
Pan Value 907 Grip Value 907 tilt Value 907
Pan Value 907 Grip Value 906 tilt Value 906
Pan Value 904 Grip Value 907 tilt Value 907
Pan Value 907 Grip Value 899 tilt Value 907
Pan Value 900 Grip Value 907 tilt Value 907
Pan Value 908 Grip Value 907 tilt Value 907
Pan Value 899 Grip Value 907 tilt Value 907
Pan Value 907 Grip Value 903 tilt Value 908
Pan Value 908 Grip Value 901 tilt Value 908
Pan Value 899 Grip Value 908 tilt Value 908
Pan Value 899 Grip Value 907 tilt Value 908
Pan Value 908 Grip Value 908 tilt Value 908
Pan Value 903 Grip Value 908 tilt Value 908
Pan Value 897 Grip Value 908 tilt Value 908
Pan Value 907 Grip Value 908 tilt Value 908
Pan Value 908 Grip Value 906 tilt Value 908
Pan Value 909 Grip Value 908 tilt Value 906
Pan Value 909 Grip Value 909 tilt Value 908
Pan Value 909 Grip Value 909 tilt Value 909
Pan Value 856 Grip Value 908 tilt Value 908
Pan Value 797 Grip Value 908 tilt Value 908
Pan Value 745 Grip Value 908 tilt Value 908
Pan Value 709 Grip Value 908 tilt Value 909
Pan Value 678 Grip Value 909 tilt Value 907
Pan Value 635 Grip Value 862 tilt Value 853
Pan Value 656 Grip Value 903 tilt Value 909
Pan Value 652 Grip Value 900 tilt Value 870
Pan Value 653 Grip Value 904 tilt Value 903
Pan Value 637 Grip Value 908 tilt Value 899
Pan Value 568 Grip Value 909 tilt Value 909
Pan Value 502 Grip Value 909 tilt Value 909
Pan Value 438 Grip Value 909 tilt Value 909
Pan Value 393 Grip Value 910 tilt Value 910
Pan Value 356 Grip Value 909 tilt Value 909
Pan Value 333 Grip Value 909 tilt Value 909
Pan Value 293 Grip Value 909 tilt Value 909
Pan Value 230 Grip Value 909 tilt Value 907
Pan Value 159 Grip Value 909 tilt Value 909
Pan Value 90 Grip Value 909 tilt Value 909
Pan Value 18 Grip Value 909 tilt Value 909
Pan Value 0 Grip Value 909 tilt Value 907
Pan Value 0 Grip Value 909 tilt Value 909
Pan Value 0 Grip Value 909 tilt Value 910
Pan Value 0 Grip Value 910 tilt Value 910
Pan Value 49 Grip Value 910 tilt Value 910
Pan Value 142 Grip Value 910 tilt Value 910
Pan Value 252 Grip Value 910 tilt Value 910
Pan Value 366 Grip Value 910 tilt Value 910
Pan Value 454 Grip Value 910 tilt Value 910
Pan Value 472 Grip Value 824 tilt Value 826 //THIS LINE notice the big dip
Pan Value 591 Grip Value 909 tilt Value 909
Pan Value 674 Grip Value 910 tilt Value 910
Pan Value 771 Grip Value 909 tilt Value 909
Pan Value 866 Grip Value 906 tilt Value 906
Pan Value 907 Grip Value 897 tilt Value 908
Pan Value 907 Grip Value 907 tilt Value 895
Pan Value 898 Grip Value 908 tilt Value 908
Pan Value 906 Grip Value 908 tilt Value 908
Pan Value 909 Grip Value 908 tilt Value 909
Pan Value 907 Grip Value 909 tilt Value 909
Pan Value 909 Grip Value 909 tilt Value 907
Pan Value 910 Grip Value 910 tilt Value 910
Pan Value 909 Grip Value 909 tilt Value 910
Pan Value 910 Grip Value 909 tilt Value 910
Pan Value 910 Grip Value 908 tilt Value 910
Pan Value 911 Grip Value 911 tilt Value 911
Pan Value 911 Grip Value 911 tilt Value 910
Pan Value 911 Grip Value 910 tilt Value 911
Pan Value 910 Grip Value 910 tilt Value 911
Pan Value 847 Grip Value 911 tilt Value 911
Pan Value 770 Grip Value 911 tilt Value 911
Pan Value 700 Grip Value 911 tilt Value 911
Pan Value 619 Grip Value 911 tilt Value 911
Pan Value 497 Grip Value 867 tilt Value 860 //And Another
Pan Value 392 Grip Value 910 tilt Value 910
Pan Value 292 Grip Value 865 tilt Value 869 //so on
Pan Value 208 Grip Value 855 tilt Value 860
Pan Value 135 Grip Value 909 tilt Value 909
Pan Value 77 Grip Value 907 tilt Value 885
zoomkat:
Its fixed
Im just an idiot and did not listen
@zoomkat
You were correct. I apologize for not listening. You were 100% correct. Thank you for the suggestion
@everyone else on the board. Thank you for all your help and helping me improve my debugging skills.
I learned a valuable lessons.
Dont assume anything is working as assumed with electronics.
Now i can turn my project in.
Thanks again fellas
