3 Shift Registers
I am trying to chain up 3 shift registers. I am pretty sure my wiring is all set but I am having issues with the code.
I am using the shift out example and changing it for a third shift register.
The problem is I am not seeing any LEDs light up on the third register after my changes.
I am guessing it has to do with this line:
shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend >> 16);
Is that not supposed to be 16 for the third register?
(You can ignore the comments as I have not changed them from the example.
Thanks in advance for the help!
Here is the rest of the code...
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
////Pin connected to DS of 74HC595
int dataPin = 9;
//Pin connected to SH_CP of 74HC595
int clockPin = 10;
  Shift Register Example
 for two 74HC595 shift registers
 This sketch turns on each of the LEDs attached to two 74HC595 shift registers,
 in sequence from output 0 to output 15.
 Hardware:
 * 2 74HC595 shift register attached to pins 2, 3, and 4 of the Arduino,
 as detailed below.
 * LEDs attached to each of the outputs of the shift register
 Created 22 May 2009
 Modified 23 Mar 2010
 by Tom Igoe
char inputString[2];
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  Serial.println("reset");
  // iterate over the 16 outputs of the two shift registers
  for (int thisLed = 0; thisLed < 24; thisLed++) {
    // write data to the shift registers:
    registerWrite(thisLed, HIGH);
    // if this is not the first LED, turn off the previous LED:
    if (thisLed > 0) {
      registerWrite(thisLed - 1, LOW);
    // if this is  the first LED, turn off the highest LED:
    else {
      registerWrite(24, LOW);
    // pause between LEDs:
// This method sends bits to the shift registers:
void registerWrite(int whichPin, int whichState) {
  // the bits you want to send. Use an unsigned int,
  // so you can use all 16 bits:
  unsigned int bitsToSend = 0;
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // turn on the next highest bit in bitsToSend:
  bitWrite(bitsToSend, whichPin, whichState);
  // shift the bytes out:
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend >> 8);
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend);
  // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
Duh....
changed to unsigned long and I am all set.
