3 wire Load cell - Increasing Sensitivity
Hey guys,
I just pulled two of these strain gauges from a bathroom scale, which look like this:
So I used two of these to make a full bridge circuit using this wiring setup and connect it to HX711:
When i press one of the strain gauges, its shows me a positive increase in the load. But the major problem is I have to press the thing very hard to show me a change.
I want to measure very small stuff like in terms of grams. How do I increase the sensitivity of the sensor? Should I make a change in the software or any mistake in my hardware.
Thank you in advance :slight_smile:
What led you to believe the gauges would read differently now than when they were in the bathroom scale? You can use a lever to multiply the force on the gauge.
Paul
No. I actually wanted a small load sensor instead of the large 4 gauge setup to measure items in a bottle or a small jar.
So I wanted to place the items over the strain gauge and measure items.
Essentially I just wanted a small single point load sensor setup to weigh items.
That is why I pulled them out from the bathroom scale.
cyberteen:
Then you should use a load cell from a scale that is designed to weigh "very small stuff like in terms of grams." Such as one of these:http://www.awscales.com/portable-precision-scales-01-gram/229-amw-100-digital-pocket-scale
or perhaps something like this might work for you:
Square Force-Sensitive Resistor (FSR) [Alpha MF02A-N-221-A01] : ID 1075 : $5.95 : Adafruit Industries, Unique & fun DIY electronics and kits.
Or, look at load cell amplifiers.
Paul
The load cells in diagram#2 are connected wrong.
E+ and E- from ONE cell has to be swapped.
So one outputs a positive going voltage, and the other one outputs a negative going voltage.
Leo..
cyberteen:
You are asking to do eye surgery with a bulldozer.
You can't. You need the sensor from a small kitchen scale, not a bathroom scale.
Thanks for the replies guys! As pointed out, I was using a load cell with excess capacity to weigh smaller items.
I will also try out the lever setup.
Thanks again
