3-Wire Serial SPI Temperature Sensor (MAX6629) with an Arduino Uno
I have brought an MAX6629 SPI sensor found here:
I have hooked up VCC, GND, MISO (Arduino) to SO (MAX6629), Pin 10 (Arduino) to CS, and SCK.
The code I have uploaded to the Arduino Uno is shown below. However I am not getting anything out? If you take a look at the datasheet, you can see the 16 bits used, is my code reading it right?
#include <SPI.h>
double readCelsius(uint8_t cs) {
    uint16_t v;
    digitalWrite(cs, LOW);
    v = SPI.transfer(0x00);
    v <<= 8;
    v |= SPI.transfer(0x00);
    digitalWrite(cs, HIGH);
    if (v & 0x4) {
        return NAN;
    v >>= 3;
    return v*0.25;
    SPI.begin();
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.print(readCelcius(10));
    Serial.print(" ");
Thanks!
Just to clarify: SCK means pin 13 on the Arduino side, doesn't it?
Does that mean you get nothing or do you get 0 as output?
With the exception that you use an unsigned integer instead of a signed one the code looks OK.
pylon:
Yes it is pin 13. I get nothing in the output.
That's weird then, I don't see what's wrong..
Do you have your Serial Monitor configured for 115200 baud?
If you have, upload a simple sketch to check the serial connectivity. You should at least see some numbers.
