3 x 3 x 3 cube
hi
i am in need of help to build a 3 x 3 x3 cube
will a adruino uno R3 be ok to do so
and how would i go about it
thanks for your time
Try here
Too funny but true !
Yes, Uno can do that. Use 9 pins to drive the anodes on one layer (with current limit resistor per anode, so 9 total for the cube), the 3 anodes in a column are connected. Use 3 transistors to sink the current from the cathodes of each layer. The cathodes of the layer are connected. A ULN2003/UNL2803 can be used in place of discrete transistors.
About 44,000 results (0.24 seconds)
Yes, looks like it can be done.
