3 x 3 x 3 LED Cube code
I have recently resurrected my 3 x 3 x 3 LED cube to write some code based on Hassan Ali’s code at -
http://www.abrushfx.com/Arduino/ledcube3.html
The posted code
 //Code based on ABrushFX Cube code at
//http://www.abrushfx.com/Arduino/ledcube3.html
//Array for three LED levels
int ledRow[] ={ 11, 12, 13 };
// Array for nine LED's in each level
int ledCol[]= { 1, 2, 3, 4, 5, 6, 7, 8, 9 };
int timer= 500;
void setup() // Sets up all pins as Outputs
  for( int i =  0; i < 3; i++)
  pinMode( ledRow[i],OUTPUT);
      for(int j =  0; j < 9; j++)
      pinMode( ledCol[j],OUTPUT);
// Sets an LED HIGH based on Row and Column position
void onLED(int ledRow, int ledCol){
  digitalWrite(ledRow, HIGH);
  digitalWrite(ledCol, HIGH);
// Sets an LED LOW based on Row and Column position
void offLED(int ledRow, int ledCol)
  digitalWrite(ledRow, LOW);
  digitalWrite(ledCol, LOW);
void topRowPaneFigure8()
      for(int y = 0; y < 3; y++)   // light LED's 1 - 3 on/off on top level
        onLED(ledRow[0],ledCol[y]);         // 7 8 9
        delay(timer);                       // 4 5 6
        offLED(ledRow[0],ledCol[y]);        // 1 2 3
       for(int y = 5; y > 2; y--)  // light LED's 6 - 4 on/off on top level
        delay(timer);
       for(int y = 6; y < 9; y++)  // light LED's 7 - 9 on/off on top level
        delay(timer);
        delay(timer);
void centreRowPaneFigure8()
      for(int y = 0; y < 3; y++)    // light LED's 1 - 3 on/off on centre level
        onLED(ledRow[1],ledCol[y]);           // 7 8 9
        offLED(ledRow[1],ledCol[y]);          // 1 2 3
       for(int y = 5; y > 2; y--)   // light LED's 6 - 4 on/off on centre level
        delay(timer);
       for(int y = 6; y < 9; y++)   // light LED's 7 - 9 on/off on centre level
        delay(timer);
        delay(timer);
  void bottomRowPaneFigure8()
      for(int y = 0; y < 3; y++)   // light LED's 1 - 3 on/off on bottom level
        onLED(ledRow[2],ledCol[y]);          // 7 8 9
        offLED(ledRow[2],ledCol[y]);         // 1 2 3
       for(int y = 5; y > 2; y--)   // light LED's 6 - 4 on/off on bottom level
        delay(timer);
       for(int y = 6; y < 9; y++)   // light LED's 7 - 9 on/off on bottom level
        delay(timer);
        delay(timer);
  topRowPaneFigure8();
  centreRowPaneFigure8();
  bottomRowPaneFigure8();
includes three functions (one for each level of the cube) that light the LED’s in a figure eight configuration as detailed in the short attached txt document. The code operates as required but in the interest of building on my limited code writing skills 8) I am wondering how to consolidate the three functions
topRowPaneFigure8
into one function. Where I am having trouble is the fact that the only difference between the three functions is the (ledRow[0] section in
delay(timer);
which is 0, 1 and 2 in the three functions corresponding to the three levels. I assume that the solution is to use a for loop, but as the " ledRow "appears unchanged four times in each function, I am somewhat perplexed. I hope that I have explained myself adequately and thanks for reading Pedro.
Cube doc.txt (399 Bytes)
void rowPaneFigure8(int row)
    // Check for range errors
    if (row < 0 || row > 2)
        return;
        onLED(ledRow[row],ledCol[y]);           // 7 8 9
        offLED(ledRow[row],ledCol[y]);          // 1 2 3
        delay(timer);
        delay(timer);
        delay(timer);
Thank you for your reply johnwasser. Do I correctly assume that you mean for me to replace my three existing functions
topRowPaneFigure8
with the modified rowPaneFigure8 function you have provided ?
If so I get the following errors
sketch_nov17a.cpp: In function ‘void loop()’:
sketch_nov17a:39: error: too few arguments to function ‘void allRowPaneFigure8(int)’
sketch_nov17a:72: error: at this point in file
Am I possibly making some mistake, here is the code I am now trying to compile and upload thanks Pedro.
int timer= 500;
        return;
        delay(timer);
        delay(timer);
        delay(timer);
rowPaneFigure8();
Replace
with
rowPaneFigure8(0);
rowPaneFigure8(1);
rowPaneFigure8(2);
or
for (int i=0; i<3; i++)
    rowPaneFigure8(i);
Thanks johnwasser.
It took me a little while to work out how to implement your suggestions, but in the end I just reduced the three functions to one and incremented the
onLED(ledRow[i],ledCol[j]);
delay(timer);
offLED(ledRow[i],ledCol[j]);
with the for loop
for (int i = 0; i < 3; i++)
so I ended up with
int timer= 500;
void rowPaneFigure8()
      for(int j = 0; j < 3; j++)   // light LED's 1 - 3 on/off on top level
        onLED(ledRow[i],ledCol[j]);         // 7 8 9
        offLED(ledRow[i],ledCol[j]);        // 1 2 3
       for(int j = 5; j > 2; j--)  // light LED's 6 - 4 on/off on top level
        delay(timer);
       for(int j = 6; j < 9; j++)  // light LED's 7 - 9 on/off on top level
        delay(timer);
        delay(timer);
  rowPaneFigure8();
This saved 550 bytes, so thanks for your help Pedro.
