On a Leonardo, I am running this sketch and I have a PIR connected to Pin 7 that gives a 'CTRL' keypress when activated, on the connected PC to wake the screen.
I also want to wake the screen every 30 minutes regardless.
Would someone kindly explain exactly what I need to write to achieve this. My head is literally spinning from reading all about interrupts, delays, registers etc. I'm sure it won't be very complicated but I am stuck.
Many thanks
#include <Keyboard.h>
// use this option for OSX:
char ctrlKey = KEY_LEFT_GUI;
// use this option for Windows and Linux:
// char ctrlKey = KEY_LEFT_CTRL;
// make pin 7 an input:
pinMode(7, INPUT);
// initialize control over the keyboard:
Keyboard.begin();
while (digitalRead(7) == LOW) {
// do nothing until pin 2 goes HIGH
// new document:
Keyboard.press(ctrlKey);
delay(100);
Keyboard.releaseAll();
maybe something like that (typed here, fully untested)
const byte pirPin = 7;
const char ctrlKey = KEY_LEFT_GUI;
const unsigned long thirtyMinute = 1800000ul; // 30 min x 60 seconds per minute x 1000 milliseconds per second
unsigned long lastWakeUp;
bool pirIsIdle = true;
void sendWakeUpWhenNeeded(bool forced = false) {
if (forced || (millis() - lastWakeUp >= thirtyMinute)) {
delay(100);
lastWakeUp = millis();
pinMode(pirPin, INPUT);
Keyboard.begin();
// handle PIR
if (pirIsIdle) { // if PIR was not triggered yet
if (digitalRead(pirPin) == HIGH) { // check if PIR got activated
sendWakeUpWhenNeeded(true); // it did, force-send the command
pirIsIdle = false; // and remember PIR got activated
} else { // the PIR had been activated,
pirIsIdle = (digitalRead(pirPin) == LOW); // wait for the PIR to go back to LOW
// handle time based wake-up
sendWakeUpWhenNeeded();
the only "complicated" part you might not have anticipated is the fact that you probably don't want to send the ctrlKey continually whilst the PIR is triggered (they usually stay active for a few seconds or minutes). so you need something that tells the code "I've already sent the notification for this PIR event, I won't send another one until it went back to rest."
I could have separated the code for the PIR and the code for the timer but it sounds easier to group sending the key when needed in one function.
So it almost works. Set the timer for 15 seconds and left it running for a bit. CTRL every 15 seconds as it should. About 7 seconds after a timed event, activated PIR and instant CTRL command. Timer kicked back in for every 15 seconds. PIR then stopped activating but timer ok. Reloaded original basic PIR program and proved PIR itself still functioning correctly. Uploaded timer program and did exactly the same. PIR stopped working after first activation but timer carried on functioning correctly. I've tried to read the code to see if I could understand why but beyond me.
Last time I wrote any code was approx. 1981 in school computer club on a ZX81!
I appreciated your time already but would you have any ideas?
Kindest regards
It seems that once the PIR has been activated for the first time from boot up, it stops passing any further 'high' signals to the Arduino. The timer does carry on working correctly.
Serial.begin(115200); Serial.println();
Serial.println("PIR IS ACTIVATED");
if (pirIsIdle) Serial.println("PIR IS DEACTIVATED");
an open the Serial monitor at 115200 bauds
you should see messages each time the PIR is activated and deactivated
So as soon as I open serial monitor, it scrolls at a rate of knots (deactivated). As soon as I activate the PIR, the scrolling stops, PIR activated comes up and then it all stops. No further PIR activation has any output to the serial monitor.
Thanks again
18:25:17.080 -> PIR IS DEACTIVATED
18:25:17.080 -> PIR IS ACTIVATED
and if that works (showing PIR status) then just set the {} right in the previous code
delay(100);
Keyboard.begin();
// handle PIR
Thank you so much, that did it.
You are a legend and I applaud you.
Thanks for sticking with it and using your valuable time.
I am now going to try and decipher the code and try and understand it.
